BUMPSTEER SETUP
  • Thread starter Thread starter KGOFF
  • Start date Start date Mar 11, 2008
K
KGOFF
63
nj
Mar 11, 2008
  • Mar 11, 2008
Hello all,
I just installed a bumpsteer set on a 88 vert with power steering.The adj. are all the way in and both wheels still point out/away from the car.The car has tube k-frame and a-arms with coilovers and i currently have the wrong camber/casters on the car(was'nt paying attention to what i was buying and have the wrong $180 caster/cambers now).The car is in the building stage and has not been properly aligined as of yet.Would this be my problem or is there an issue somewhere?
thanks
keith
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Mar 11, 2008
  • Mar 11, 2008
i would imagine the wrong caster/camber plates could throw you off pretty bad. iwould address that issue first
347HO
462
Seattle
Mar 11, 2008
  • Mar 11, 2008
Are you describing the front of the wheel/tire is pointing away from centerline?
Or are you describing the top of the wheel/tire is pointing away from the fender?
If it is the first, then your tie-rod end adjusts that.
If it is the second, then your camber adjusts that.
You castor is adjusted moving the top of the strut fwd or rear in the mount.
Bump steer is a whole different animal and you must first have the correct attitude/hieght/reference on the front suspension before tuning for that.
Get with your Kmemeber manufacturer... they should know what you need to correct for anything that changes when using their kmember.
K
KGOFF
63
nj
Mar 11, 2008
  • Mar 11, 2008
Front of the wheel/tire is pointing away from centerline. Both front tires are pointing in opposing directions which I believe to be tie rod/bump steer end adj.I have brought both adj.to it's beginning most point and it still is out of line.The k-frame was boxed out for proper alignment when installed and manufacturer said the a-arms would bring the wheel base out which would/should give me more adj.options with the bump stop ends,im not trying to adj.bumpsteer as of yet.
347HO
462
Seattle
Mar 11, 2008
  • Mar 11, 2008
So........ do you have a front steer setup?
You should only have to break the jam-nut loose on the steering rod end and turn the barrel to "pull" the nose of the tire in toward centerline. You should do both sides in increments of the same amount of threads.
You need to fab up an alignment fixture which extends the full width of your car to measure both front wheels at at the nose of the wheel or tire and then measure the front wheels at the trailing half of the wheel or tire.
Once you have it "eyeballed" close, you can use this fixture to dial in your toe alignment perfectly.
This does not however align your front wheels with centerline. To do that you need to use a "center" reference point to measure from there to the nose of both wheels and ensure that measurement is equal on both left and right wheels.
Then you would turn one barrel one way and the other the opposite to correct for your out of alignment.
K
KGOFF
63
nj
Mar 12, 2008
  • Mar 12, 2008
thats the problem 347 im out of adj to pull them in twards center line.I just orded the new caster/camber plates from mm and ill give it a second shot once i install the plates.Thanks for all you time and help and im sure ill be back...
keith
Resolved 2015 ecoboost pp bumpsteer issue
  • matthewt
  • Aug 1, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Aug 3, 2026
fasterthangas
F
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
A
SOLD For Sale: 1993 Ford Mustang Cobra Modified
  • anjteal93
  • Sep 5, 2025
2K
Fox Body Mustangs For Sale (1979-93) Oct 26, 2025
Mindseye007
Suspension SetUp
  • 23Newb
  • Jul 29, 2023
  • 2.3L (N/A & Turbo) Tech
  • 2 3
7K
2.3L (N/A & Turbo) Tech Sep 4, 2023
23Newb
Wheels-Tires LS mii swap and rear rim size/axle questions....
  • 78mIIman
  • Feb 2, 2025
1974 - 1978 Mustang II Talk & Tech May 6, 2025
78 Mach1
