Burnouts
  • Thread starter Thread starter nightrider50
  • Start date Start date Jul 7, 2005
N
nightrider50
186
California
Jul 7, 2005
  • Jul 7, 2005
How do guys at the track do their burnout before they line up and stay in one spot for so long? I need to get my tires warm for that 60 ft time...
ramjetlx
212
Honolulu, Hawaii
Jul 7, 2005
  • Jul 7, 2005
Do you have a manual or auto? With an auto just slam on the brake as hard as you can and then floor the gas. Maybe someone with a manual can explain how to do it.....
BlownStangGT
REPEAT
3,860
Lancaster, PA
Jul 7, 2005
  • Jul 7, 2005
with a manual...you can....hold in the clutch, rev to 3-4k, let the clutch fly with ur left foot and quick grab the brake, this will hold it thier and yu can do ur burnout without moving....or you can hold ur left foot ont he brake, and the right heel on the clutch and right toes on the gas, slowly let out the clutch and give it gas till it spins...I have done both, and find the 2nd of the two a little harder, option number 1 is really easy
wildstanggt
186
Omaha, NE
Jul 7, 2005
  • Jul 7, 2005
The best way to burnout in a manual is to pump the brakes to build up brake pressure then rev to 5500 rpm and dump the clutch and then slam the brake. Hold the RPM's untill the hides are nice and smokey and then ease off the brake and gas and you will slowly creep froward to the staging line.
Scorcher2005
883
South Carolina
Jul 7, 2005
  • Jul 7, 2005
when i hold the brake with my auto, only one tire spins :-/
wildstanggt
186
Omaha, NE
Jul 7, 2005
  • Jul 7, 2005
ohh and second gear burnouts work the best IMO!
393Bird
244
Clarksville Tennessee
Jul 7, 2005
  • Jul 7, 2005
The best way is to install a brake line lock on the front brake lines. Hit the brakes, depress the lock button, release the breaks, put the power to it. The front brakes will stay on till you release the button. Saves on the rear brakes and allows higher speed burn outs to get the drag radials of sloicks nice and sticky.
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Jul 7, 2005
  • Jul 7, 2005
N
nightrider50
186
California
Jul 7, 2005
  • Jul 7, 2005
I have a manual. i think ill just do it the easy inexpensive way and dump the clutch then quickly put my left foot on the brake. thanks guys!
JimBowy
330
Downriver, Mi
Jul 7, 2005
#10
  • Jul 7, 2005
  • #10
Will cost you under $55 to get a cheap Biondo LineLock.... Thats what I use.
93GTosu
183
#11
  • Jul 7, 2005
  • #11
how hard is it to install a line lock???
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jul 8, 2005
#12
  • Jul 8, 2005
  • #12
The way my pedals are spaced it's relatively easy to to put the left side of my right foot on the brake pedal, and the right side of my right foot on the gas pedal; left foot works the clutch....
"...or you can hold ur left foot ont he brake, and the right heel on the clutch and right toes on the gas, slowly let out the clutch..." Think about it for a minute......I'd sure like to watch that technique...
The Shape
2,224
East ARKANSAS Delta
Jul 8, 2005
#13
  • Jul 8, 2005
  • #13
Yeah you would need one hell of an arch in your foot for that to work.
cleanLX
976
537
144
Jul 8, 2005
#14
  • Jul 8, 2005
  • #14
mmmm... nothing like the smell of fried clutch...
don't forget all this is based on the idea that you've already rolled thru the waterbox.
if you are running fullsized front tires, do everyone a favour and drive around the waterbox, and back in to wet only the rears. if you are runninf skinnes, driving thru the box is fine.
pull the rears out of the water, and onto the damp portion of the burn box.
pull it into 2nd gear and wait for the burn box director to signal it's time to go.
grab second gear, dial up 5000rpm dump the clutch and grab a little brake.
It takes very very little brake to hold the car... you do not need to mash the brake.
watch both the tach and your speedo.
if the mph starts to fall and the rev's are not, then, you are cooking your clutch.
Hold steady throttle, bouncing rev's wil tear up the drivetrain, especially the trak loc.
when the rev's start to drop your tires are warm... let off the brake, then get out of the gas.
roll up and prestage
Have fun.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jul 8, 2005
#15
  • Jul 8, 2005
  • #15
" Yeah you would need one hell of an arch in your foot for that to work. "
...or a set of wicked '70's disco double platforms....
N
nightrider50
186
California
Jul 8, 2005
#16
  • Jul 8, 2005
  • #16
I have a set of nitto 555dr's in the back. what tire pressure would be best with the 2nd gear burnout?
JimBowy
330
Downriver, Mi
Jul 8, 2005
#17
  • Jul 8, 2005
  • #17
It's not very hard. The biggest issue is modifying a T into your brake lines. Do some searches about Linelock, a few guys have posted "How To's" on the project.
Drivetrain Tail Shaft bore odd shape
  • R82148V
  • Jun 12, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
Mustang5L5
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
J
Traction Whipple stage 2
  • Jimmy koutoulas
  • Aug 2, 2025
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Aug 12, 2025
R
Suspension Drag Radial Issue
  • Rcdgl
  • Apr 7, 2025
Fox 5.0 Mustang Tech Apr 7, 2025
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
