- Apr 12, 2008
- 28
- 0
- 0
ok im looking at a 02 gt w/ a v-2 s trim n water to air intercooler EVERYTHING else is bone stock on the car. the guy doesnt kno much of anything about the car. its clean and a good deal but when i pulled into the driveway after ripping on it there was smoke comming from the under carrage so i look and there is oil burning on the back of the mufflers and a lil on the chassis the diff seemed dry so im confused as to what could b leaking. car only has 44k on it n when i hit second hard i heard a lil grid on the gear, it has the stock clutch cant handle the power? cuz i had the cluth all the way down. it also has a slight grind, sounds lik a rubbing on the drive shaft sound once or twice, last part is he never did any up keep with the power cooler, dont know anything about these could this b harmful to the cooler?
) Grinding isn't always a bad trans, it could be the clutch.
