BUYING an old engine HELP!!!!!
  • Thread starter Thread starter lookout4me
  • Start date Start date Apr 26, 2005
L
lookout4me
Banned
Apr 3, 2005
35
  • Apr 26, 2005
I am about to buy a 351w for a 67 coupe but i dont want to run into any troble when i am going to buy the engine.
:OT: do you guys have any suggestions on what i should look for or ask about
he is asking 350 for a running engine it needs a rebuild. and also how much dose a complete rebuild cost?
D
damannhw
173
Upstate SC
Apr 26, 2005
  • Apr 26, 2005
Is it running ? If so, that would be nice because you could hear it run and check the oil pressure if you take a gauge and adapter. You could also do a compression check ? But, if you are gonna rebuild anyway, may not be worth the trouble. If I was looking for a builder, I would just want to hear what I was buying and see that it was complete. See if he will "make it good" if you find any surprises internally. Good luck !
L
lookout4me
Banned
Apr 3, 2005
35
  • Apr 26, 2005
yea he said it was running but how would i test it it is out of the car.
D
damannhw
173
Upstate SC
Apr 27, 2005
  • Apr 27, 2005
Well, if it's out already, hearing it run is out of the question. How soon are you gonna rebuild it ? Any chance he would let you take it to your shop and let them tear it down and inspect ? I would hate for you to get a block that has been bored a couple of times already.
351LX
1,007
Regina, Saskatchewan
Apr 27, 2005
  • Apr 27, 2005
You can get a good idea of the condition of an engine by looking at the spark plugs, the end should be brown.If they are black and oily that is a bad sign and if you pull a spark plug and find antifreeze or water that is a very bad sign.Rotate the crank with a socket on the front and make sure it turns over ok and is not seized.Since they are selling it as needing a rebuild you have to assume that at best it is tired, at worst it needs major mechanical parts.The cost of a "rebuild" can vary greatly.A true rebuild would involve boring out the cylinders, grinding the crank ,new valve guides and replacing just about every moving part in the motor with new ones which can easily cost over $2000 with standard parts and more if you are replacing them with hi-performance stuff.In that case you might be better off just looking into a crate motor, especially if you would have to pay someone else to assemble it.
G
Need tuning help with 4100 Carburetor
  • Gary’s 67
  • Aug 18, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 22, 2026
manicmechanic007
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
