It’s really not worth the hassle for a street car. Some believe there is a temperature drop because hot engine coolant isn't circulating through the spacer, but if you've still got all your pollution controls functioning, that circulating coolant is the only thing cooling the even hotter exhaust gasses flowing through EGR passage. Bypassing it with a car that is still subject to smog testing will actually increase temps, not reduce them. In any case….the differences in performance between the two are negligible at best. Any performance gain felt at all is accomplished by removing the vehicles smog system altogether…not just by bypassing the coolant passages on the spacer alone.
