bypass valve
JD1964
there is enough sticking out to grab on to
3,639
1,659
194
Maryland
I'd like to install a standard bypass valve for my Vortech setup since I'm running 10psi boost. I currently have the standard plastic discharge pipe. Have any of you seen or know of a reasonable way to add a fitting to the plastic pipe? I'm trying to avoid spending on a new metal discharge pipe if at all possible. I figure a plastic pipe will insulate against underhood heat better too.
