C-4 or AOD
  • Thread starter Thread starter foxstang9050
  • Start date Start date Aug 9, 2006
F
foxstang9050
158
El Doarado Hills, CA
Aug 9, 2006
  • Aug 9, 2006
My AOD is gone... not sure whether to put another AOD or go to the C-4... i wanna do the C-4 because i hear its lighter and stronger... which is better
LX302
Stanger
728
Bethlehem PA
Aug 9, 2006
  • Aug 9, 2006
Not sure about it being lighter, but depends on what kind of driving you do.
Highway? Then you wanna keep an AOD.
Just street driving and keep the cost a little lower? Then a C4, as it's only a 3 speed.
But others will tell you to go with a T5 conversion.
eagleautosports
139
Mebane NC
Aug 9, 2006
  • Aug 9, 2006
The C4 is stronger and better for racing. The AOD keeps a little gas mileage and with a few extras can be made just as strong as a C4.
R
R2D2
Aug 9, 2006
  • Aug 9, 2006
C4
F
foxstang9050
158
Aug 9, 2006
  • Aug 9, 2006
How does this deal look???
http://cgi.ebay.com/ebaymotors/FORD...008QQitemZ180016114593QQrdZ1QQsspagenameZWDVW
A
Al CapownU
  • Aug 9, 2006
deal looks bad ass I bought a valve body from them and they have excelent costomer service and the price owns all.. I love my C-4 verses 5spd. and I hear aod are junk unless u have some serrious change to buy a good one.
R
R2D2
Aug 9, 2006
  • Aug 9, 2006
I would be all over that, redneck makes some good converters. If you never had a good automatic your in for a surprise. C4's are great.
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
Aug 9, 2006
  • Aug 9, 2006
i l0ved my c4 when i had it in the car but i have t0 drive it everyday and take it 0n r0ad trips every 0nce in a while and with a 2800 stall i wasnt t00 g00d 0n the highway.
92LX_Stroker
22
Where ever the Army puts me
Aug 9, 2006
  • Aug 9, 2006
What is a T5 coversion? I am running a 3000 stall in my C4, but heard a manual was better for the 347ci, yes/no???
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
Aug 9, 2006
#10
  • Aug 9, 2006
  • #10
t5 manual tranny c0nversi0n. id think that 3k stall and a c4 w0uld be better than a t5 especially since the t5 w0nt last l0ng behind that m0t0r at the track
F
foxstang9050
158
Aug 9, 2006
#11
  • Aug 9, 2006
  • #11
Well if im runnin that C-4 with 4.10 gears... would that be bad??? Should i go more with 3:55 or 3:73???
Jaswir
578
Orlando, FL
Aug 9, 2006
#12
  • Aug 9, 2006
  • #12
c4 bolt right up? or do u need a different flexplate?
F
foxstang9050
158
Aug 9, 2006
#13
  • Aug 9, 2006
  • #13
From what i know... correct me if im wrong... but the c-4 will bolt up just fine to a 5.0 witht the stock 50 oz
flex
MrKwik
1,008
Kansas City, Kansas
Aug 10, 2006
#14
  • Aug 10, 2006
  • #14
flex
Yes and no but mostly no. Technically the AOD flexplate will work if you are using a 164t bellhousing on the C4. Problem is that I have found the big bell to have clearance issues in a Foxstang. I tried it once and it hit the H-pipe and there was no way O2 sensors would have fit if I had needed them. This was with shorties and I'm pretty sure it would have been worse with long tubes. The 157t bellhousing fits much better but they are getting hella hard to find. Now if you use the 157t bell like I did, you will need an aftermarket flexplate since any factory 157t flexplate used with the c4 would have been 28oz. TCI makes a 157t/50oz flexplate for use with a c4/5.0 and it was only like $65. Also keep in mind that converters are specific to which flexplate/bell you are using so make sure to get the correct stall for your setup.
Now beyond the techincal stuff...the C4 is definately lighter than an AOD and for racing I think its a better setup since you dont have the one-dee-one shuffle to deal with (unless you have a built AOD) but in a daily driver with deep gears, its a pain. I had a C4 with 3.73's in my 93 vert and it was no fun on the highway at all. If the budget allows, I would say a nicely built AOD would be the way to go in a car that sees much street time.
F
foxstang9050
158
Aug 10, 2006
#15
  • Aug 10, 2006
  • #15
It doesnt see much street driving... its mostly just a weekend car so im to worried about that
Spot U 2
21
#16
  • Aug 11, 2006
  • #16
I run a C4 with 4.10s and a 28in tall tire. Not to bad for street driving, but the rpms are high on the highway.
I'm deep into the ten with the combo and would never look back. I went from a t5 to the C4.
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Aug 11, 2006
#17
  • Aug 11, 2006
  • #17
What balance does a 1968 302 use and a 1982 c4? I bolted those two together with the larger bellhousing and it worked fine? Are they supposed to be different balances?
R
R2D2
Aug 11, 2006
#18
  • Aug 11, 2006
  • #18
28oz and the C4 doesnt care what the motor is balanced to
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Aug 11, 2006
#19
  • Aug 11, 2006
  • #19
im using the 1982 mustang gt flexplate tho, wouldnt it be for a 50oz?
D
AOD TV cable replacement bushing - loose pin?
  • DuluthFoxbody
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 2, 2026
DuluthFoxbody
D
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
