So here's the rundown of the car. Its an 86 coupe with an 86 302 and an 86 speed density computer in it, which is a VR1 for a manual car. And it has a c-4 transmission in it, which will hopefully be changed to a manual in the future.
According to the vin and door codes the car is an original 4 cylinder, 4 speed manual car. Anyways all the wiring is in the right place, hooked up to the appropriate places, except a few places.
Which leads to my code 67 that I get when KOEO. The car obviously has the neutral safety switch bypassed, as the car will start in any gear, so from the process of elimination I assume the a/c not being there is the problem. I removed the a/c because the only thing there was the compressor. The wires to it are still visible, hanging out over the valve covers to the plug which was hooked to the compressor.
Is there any way to fix this issue? Would just connecting the two ends of the wire together work?
I really need to check the codes as it's not running right and this is the big pita that I just can't get past
And question two, which should be less complicated. I do not have a kickdown cable or rod for the c-4 and have no idea where to get one. Could someone please advise me where exactly to find one? or what I need to use.
