Everyone,
I've been looking at the three plenums and I really can't tell a huge difference between the three. This is what I see though....from looks alone mind you!
Accufab- Almost a modified version of the stock plenum, still square in shape and polished.
Trick Flow- a new design with a more tubular design that according to the trickflow.com site, is located 3/4" higher than the stock plenum. It looks as though the air flows straight in then curves down into the lower.
C&L- same tubular design as Trick Flow but it seems like as the air enters the plenum it actually curves up, then down almost in a slight U-shape when it enters the lower.
Looking at the C&L and Trick Flow, the trick flow may be taller from the inlet to begin with and the air doesn't LOOK like it has to bend up then down because the inlet is already located 3/4" higher than the C&L inlet. I hope that makes sense. Does anybody have any inlet diameters that could be looked at as well? Just trying to break them down to see if they are really different at all or its just the name or the finish that separates them. Thanks!
Nate
Nate
