  • SN95 4.6L Mustang Tech
C&L Performance
  • Thread starter Thread starter dankgordon24
  • Start date Start date Jun 5, 2004
D
dankgordon24
61
  • Jun 5, 2004
Guys, I bought a C&L power pipe for my 96 mustang GT.
I have tried everything in my power, but I just can't make it fit around the damn strut tower brace. I called them and they confirmed that I have the right C&L part, but it just won't fit.
Do you think I will have a hard time returning this item to C&L?
I don't think I am at fault, because I bought an item that I was told would fit a 96GT, but mine canme stock with the strut tower brace.
Any and all thoughts appreciated.
Dan
Go HoTO!
602
Mountaintop, PA
Jun 5, 2004
  • Jun 5, 2004
They should take anything back within 30 days no matter what the complaint. I would simply ask them if they would take it back. Ask them for a RMA # (Return Material Authorization).
BlackenedSVT
1,841
New Jersey
Jun 5, 2004
  • Jun 5, 2004
take the strut tower brace off and then put the inlet tube in? ... then put the brace back on.
Go HoTO!
602
Mountaintop, PA
Jun 5, 2004
  • Jun 5, 2004
Wow dude...sounds like a good isea, but if his is on like mine, it is never comming off. Those things are a pain in the ass. It would take me 4-5 hours to remove and put back on OR drop the springs.
D
dankgordon24
61
  • Jun 5, 2004
Impossible
Guys, it is impossible to do just that. I have already tried unbolting the strut tower brace and wedging it up a few inches to work, but there is still no way in hell that it will fit.
Any other suggestions?
D
dankgordon24
61
  • Jun 6, 2004
DoctorGeek97GT
199
Ottawa
Jun 6, 2004
  • Jun 6, 2004
After much dinking around, I finally got my C&L inlet tube to fit WITH my stock tower brace. And I think my situation was worse than yours -- I have a roots blower that raises the TB location. Of course, I had to take the brace off first to make the fit first. Here's 2 things that I did to make it work:
1) That rubber collar + rubber insert can work to your advantage. Put that rubber insert on the throttle body, but don't necessarily slide the pipe-collar all the way up onto that rubber insert (you don't need to, and those clamps should make sure you have a good seal on at the TB).
2) At the filter-end (I have an open K&N filter) I have a bracket that supports that end of the pipe against the engine compartment. The bracket location is important -- if it's too low, the C&L pipe hits my valve cover. If it's too high, the K&N hits the hood.
The fit is tight, but nothing hits even on bumpy roads or engine-torque twist. I have maybe 1/8 to 1/4" of clearance at the tower brace and valve cover. Note that if the C&L tube touches the tower brace, you'll get wicked engine noise and vibration in the passenger compartment. Pics are included -- good luck!
D
dankgordon24
61
  • Jun 6, 2004
  • Gulftown980x
  • Jul 29, 2026
squeak93
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
2010 V6 Sees differently than GT?
  • 6t9Mach1
  • Mar 31, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Apr 1, 2026
6t9Mach1
Help with identifying original owner
  • Brynden29
  • Aug 9, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2025
91AOD5.0LX
