You need a matching block plate, flexplate, torque converter, bellhousing and C4. An aod blockplate and flexplate will work. I believe they are 164 tooth units with the 11+ in large bolt circle. The flexplate has to have the right balance for your engine, 50 oz type for 93. I only mention this because C4's go way back and early flexplates are 28 oz.
The stock auto trans starter should bolt in. The crossmember should work, as should the trans mount.
The speedometer cable for an aod works, I think. I know the gears interchange. T5 gears don't fit.
The C4 needs a hose to the modulator of manifold vacuum. It also need a kickdown linkage to the carb or throttle linkage if you want it to downshift at full throttle. If you go with a fully manual valvebody, you can get by without those.
Needs a shifter. I believe an aod floorshift will work.
Also need the neutral safety switch. The C4 mounts it over the shaft where the shift lever exits the housing.
A matching driveshaft yoke. Remember to get a trans dipstick. Also cooler lines.
