alright im sooooo close to getting my car up and running again but my clutch cable came unhooked from the top of the cable. how do i get it hooked back on?? anyones input would be great help, im sooooo close!
The cable came undone from the quadrant? If so, you need to rehook it up and tighten the cable more. Adjusting it from under the car, you can use your finger to feel when you have removed the slack (the cable is exposed a little as it leaves the sheath and goes into the clutch fork). Set it so there is zero slack for right now.jmd2914 said:alright im sooooo close to getting my car up and running again but my clutch cable came unhooked from the top of the cable. how do i get it hooked back on?? anyones input would be great help, im sooooo close!
I figured you were busy with the new motor.v8only said:you beat me to the pic posting!!! That pedal assembly quadrant has one broken hook (you can see it in the pic) but it doesn't really look different than that pic.
Sorry to hear that Jeremy. I figured you had that thing up and running by now - I know how little things take a bit to get ironed out though. Best of luck with it.v8only said:dude, that motor blows, I can't get it to run right. I'm gonna pull my upper/lower intake off and drill it the right way for act and egr coolant, then hook up ALL of the smog properly and troubleshoot from there.
