I'm also using the McCleod T/O bearing in my 89 Ranger with a Toploader 4 speed. The Ranger's M/C is a 7/8 bore ( there are also 3/4 bores available for the Ranger) The banjo fittings that the McCleod came with suck big time, they leaked after a month. I replaced them with AN style fittings. The AN adapter fittings came thru Summit Racing and are made by Aeroquip for brakes. The AN-4 lines were made up by the local parts house. This setup requires that the T/O bearing be installed first in the bell and the trans stabbed thru it. Not hard to do. I've had to adjust the bearing once for clutch wear after about a year of daily use. There is a narrow margin of adjustment in the way it works, the total travel isn't much, only about 1/2 inch. The other problems I've had with it stem from the firewall cracking and pushrod/pedal geometry in the Ranger. If I had used something like a Tremec or T5, I'd have gone with an external slave cylinder arrangement, they'd be a lot easier to adjust and fix leaks. But with the Topoader's external shifter arrangement and the Ranger's tight drive tunnel, make it impossible to fit an external slave.
