  • 2.3L (N/A & Turbo) Tech
CAI question
  • Thread starter Thread starter jasoncarmony
  • Start date Start date Jun 23, 2004
J
jasoncarmony
37
Live wherever the Air Force sends me. Right now I
Jun 23, 2004
  • Jun 23, 2004
I put a CAI in my 88 stang (n/a). I have a question about the old air filter box, do i take that completely out, and if i do, what about the hose that connects to the exhaust. What do i do with that? Can someone please help me?
351wcoupe
1,811
Manhattan, Kansas
Jun 23, 2004
  • Jun 23, 2004
Take the old box out completely. That hose just helps during a cold start, ditch it
J
jasoncarmony
37
Jun 24, 2004
  • Jun 24, 2004
awesome, thanks
so it doesnt matter it there is a whole where the tube connected to the exhaust
Beefy
62
Toronto, Ontario
Jun 24, 2004
  • Jun 24, 2004
The hole in the exhaust is actually just in the heat shield around the header. You can take the hose off without fear of anything leaking. Just make sure you plug the small rubber vacuum lines going into the top of the air box.
Lex
248
Halifax NS. Canada
Jun 24, 2004
  • Jun 24, 2004
Theres actually only one Vacuum line to worry about. When I did my CAI . I just screwed a screw in the line. The other line actually just connects the top of the stock air filter box to the bottom of the box. I completely ditched my stock stuff.
G
Gtask8
  • Jun 24, 2004
Take it alll out....then shoot it!!!
J
jasoncarmony
37
Jun 25, 2004
  • Jun 25, 2004
Thanks for all the input. I have another question, but it doesn't relate to the CAI. I am wanting to take the awesome luggage rack of the trunk of my car, but it is held on by rivets. Does anyone know how to do this? I should just post a new thread, but i will wait for responses first.
kiddiccarus
The first widely accepted Tranny
20+ Year Stangneter
Dec 24, 2003
1,789
1,051
143
30 Mins from a Ragged GT
Jun 25, 2004
  • Jun 25, 2004
Yep New thread. I dont have one but I would say it will take a drill Bondo and paint.
Drill out the rivits, bondo the holes and then paint it up.
See the new thread will help others that have the same question search better.
Ray III
586
fixin Boomhower's John Deere in Troy, NY
Jun 25, 2004
  • Jun 25, 2004
what did you replace the stock trash with?
and the hot air intake tube was intended to keep the intake charge at a proper temperature for good fuel atomization during cold weather operation. It obviously would not help with a cold start if no hot exhaust had been produced yet.
JamesBaumann
624
Vancouver Island
Jun 26, 2004
#10
  • Jun 26, 2004
  • #10
I think that the tube connecting the stock airbox to the exhaust manifold is just to help your car warm up on cold days once it has been started. Instead of just taking in the cold air from outside and burning it on cold mornings, it takes a little bit of warm air from the exhaust and it supposed to help it to warm up. However, I dont really think it'll make that much of a difference. Just ditch it. I dont have mine on anymore because the hose ripped, and mine seems to work just fine.
I
IslandBlueStang
24
#11
  • Jun 28, 2004
  • #11
do you have to plug the vaccum lines or not ? and why ?
Ray III
586
Jun 28, 2004
#12
  • Jun 28, 2004
  • #12
there is 1 hose that is the vaccuum supply for the door in the airbox that meters in warm air as necessary. Remove it and plug its connection at the vaccuum manifold on the firewall. If it is left open you have a vaccuum leak which lets air into the engine.
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
L
2000 Mustang PATS - Broken Key and Wire - HELP!
  • Laree Taylor
  • May 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
manicmechanic007
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
Airaid reduction sleeve?
  • BriansNSane
  • Dec 20, 2025
SN95 4.6L Mustang Tech Dec 20, 2025
BriansNSane
