Guys
I could not say I understand all that stuff as well
Several years ago, many of us at that time discussed that issue for several
days and I ended up using a value of 392 in all cells for my combo
I can say I found my idle was more stable and the cam lope was not
as radical which was a blessing to my way of thinking
My drivability has been quite good using that value
Much more knowledge has been learned by the self tuning
community since then. I might could go over all that stuff
again and make some improvement.
BUT
Doing all that is not very high on my priority list of things to do
Of course ... that old thread was lost when they had the big
change
which was in name and server I suspect
Which brings up a another thing to consider
Anytime you see info that .........
you can use now
might use in the future
or
you might not understand it at the time you were exposed to it
but
you can tell ... its something important
etc, etc, etc
Set up on your hard drive a Tuning folder with sub folders for things
such as Closed Loop Tuning where you put your files on topics like
lambse, kamrf, adaptive, etc. You would want a folder named Open
Loop Tuning for stuff on fuel&spark tables, high speed enrichment,
and so forth.
You'll end up with a database of info that will be of so much help and
you will find as your knowledge grows ... that stuff you put in there
that you did not understand at the time ... you now do and it is
right there on your hard drive for you to instantly use
Guys ... none of us can remember all that stuff
Some of the time ... you find some really good stuff ... and later ...
you want the info ...but ... you can't find ... or ... it was lost on
some server that crashed
Here is one really BIG bummer about not saving good stuff as you
run across it
Many times you guys ask about something I understand
As a matter of fact ............. Once upon a time ..............
Right here on this very site ................
I gave info with charts or tables or other very detailed info
to help others understand
Some of that stuff took me a good while to compile for all to see
I don't even wanna do it all over again
so
Why not point peeps to the thread as the info is still valid
Lots of the time ... I can't find the info
and
Its my own dadgum post I'm looking for
I know the info the info is on the site all right
but
Its usually buried in some thread where the topic of conversation
had changed 180 degrees from the original posters Q
Anyway ... if you don't build for yourself a database of info ....
NOBODY else will
Grady
