Caliper sticking?
FoxRod87
243
Carolina
How do I know if there is one sticking? My buddies 96 cobra is making a squeeling noise going down the road on the driverside rear. It has new brakes on it all the way around. He just got the car 1month ago. If it isn't the caliper what else could it be. And when he hits the brakes the squeel goes away. Thanks.
Well you can pull the wheel and look to see if it is sticking. Just spin the hub and if it moves freely, then you know it is not sticking. Did he twist the caliper piston back in before he put on the pads and reassembled it?
The brakes were done before he got the car. We pulled it down to put brakes on it and found that they had just been done. And I think it spun fine but I can't remember it were spun it or not. What else could the squeling be?
And the slide pins are on the front calipers and not the back.
There are also slide pins on the rear calipers, and they are prone to seizing which usually causes the inside pad to press into the rotor when the brake are not being applied. It could be the cause of the noise especially if one of the pins was seized and the previous owner just slapped the pads in without unsticking it.
Seen it happen dozens of times
hey just to let you know I had to change both front rotors on my 2000 gt because I noticed the car would not roll back on hills. When jacked up, it was really hard to turn the front left wheel and the right front was a little easier but still locked up. It is most likely your caliper IF your brake hose is okay.
The slide pins you are talking about are they the clips that hold the pads in the bracket or what are you talking about? Be more specific. Thanks.
Caliper on the left is taken apart. The bracket above has two bolts sticking out of it. Those bolts are screwed into the slide pins. They are greased up pins that ride in bores inside the bracket and slide in and out and center the caliper when you press the brakes.
On the caliper on the right, you'll see the protective dust boots. Water usually gets underneath and rusts these pins in place locking the caliper and allowing it to only press from one side. It's VERY common.
Another shot of rear caliper showing the bolts and the boots where the pins are.
Usual symptoms are noise like a squeal or grind when the brakes are not applied from the inner pad pressing against the rotor because the pins won't allow the pad to center. People usually discover this right after a fresh brake job because you have nice fat pads and nowhere for the calipers to go.
If you let it go, it tends to grind the inner pads down to the backing plate and eat the inner rotor...while the outside pad and rotor look perfectly fine.
That's about the #1 Mustang brake problem right there. In fact it's a common Varga brake caliper prob. My Mustang was 2 years old and i discovered one pin seized during a routine brake check. Luckily i fixed it in time.
I had the same problem one day after bleeding my brakes. Turned out that I had accidentally bent the dust shield when I was in there, and it was scraping against the rotor. Could that be the problem?
EDIT: Nevermind. I'm glad you found the problem.
