Greetings guys,
calling out all COOLING guru's-I need help. i thought-I use to be a cooling guru until-I git stupmed on this-WTF!!!!!!!!
When-pressure testing a cooling system, rather cap and rad, I seem to be losing 1lb within the system. I would lose 2lbs, until i bypassed my heater core, it dropped to only 1lb-But no visual leaks whatsoever!
and it seems that i have a "tink'Tink" metallic noises coming from the cooling system as well. I took out the T-stat temporarily to eliminate it, yet still have this noises coming directly from the T-stat housing and lower manifold, as well as the 2 water pump hoses and upper rad hose. its like vibrartion, thump, thump on the hoses itself. My water pump is a edlebrock hi-flo unit which was installed last year with my Fluidyne rad. i dont get it, why-I also gets lots of bubbles in the rad as well with T-stat, and i ran a Snap-on head gasket teats on the new AFR heads-which passed, no H/G leak. im really stumped here...
Funny thing, Once we pumped up the sytsem with air, (3 additional lbs) using the Stant rad rad/cap tester-the noises goes away completely, when you release the air, the noise comes back.... As well-as disconnecting the belt, noises gone, re-connect it-noise back again...WTF could this be, a bad Water pump/impeller????
All thoughts/ideas are welcome-please & thank you for your help!
Anthony
Anthony
done that @ this point and im still lost.
