- Jul 10, 2005
- 946
- 0
- 16
I just turned 17 and I'm on very tight budget. I'll be getting my crank and flywheel back from the machine shop by Thursday and I'll be ready to start putting the engine back together for the most part. I've got a set of 950-16 dual valve springs from Comp Cams that were given to me free of charge. They've got 130lbs seat pressure. They're rated up to .600" lift. On the box it says 1.450". What does this mean? What I need to know is IS THIS TOO MUCH PRESSURE FOR THE STOCK CAMSHAFT? I also need to know if I would benefit from advancing/retarding the camshaft on a stock headed engine. I've got a new Cloyes three-way timing set to make it easy.
I'll probably slightly port the heads. Will I benefit from this even using a stock camshaft? I'm pretty sure I would, but I'm not sure. As soon as I get my engine back together I'm going to get my front end aligned and get some new tires. Then I'm getting a Tweecer so I can eliminate my speed density problems. This will work won't it? The reason I'm not going to get a cam is that the guy I was going to get my mass air swap components from has lost touch with me and vice-versa.
:SNSign: Thank for your help guys....that's if I can get any.
