cam id help
rebelcowboy
46
i need help identifying this cam i have,it says 211 223 on it and thats the only part number on it,i was told it was an edelbrock that is the same as an e cam,but i dont know,i cant find that part number that is on the cam anywhere.
Unfortunately, I don't know what that stamping would correlate to specifically.
But if this helps you at all, Edelbrock does have a 5.0 cam that is the same thing as the Ford Motorsport E-303 cam, which, is also the same thing as the Crane PowerMax 2040. I believe that Edelbrock and Ford Motorsport (who each don't have their own cam grinding facility) simply rebox the Crane 2040 PowerMax.
Specs:
Adv duration: 282/282
220/220 duration @ .050
lift: .498/.498
Minimum RPM: 1400rpm
Maximum RPM: 5200rpm
Valve Float: 5800rpm
