  • SN95 4.6L Mustang Tech
Cam Install
  • Thread starter Thread starter ALEX2028
  • Start date Start date Oct 31, 2005
A
ALEX2028
57
  • Oct 31, 2005
I Want To Get A Set Of Vt Stage 1 Cams Installed By A Buddy Of Mine He Told That He Has Never Installed A Set Of After Market Cams. Would Installing These Cams Be Any Diffrent Than Installing A Set Of Stock Cams. Is There Anything He Might Need To Look Out For.
HP Addiction
261
Long Island
Oct 31, 2005
  • Oct 31, 2005
Shouldn't be much different than a stock install from my understanding. Might want to upgrade your valve springs while everything is apart. Car will also need a dyno tune to get it running properly with the new cams. I'm sure someone else wil chime in if I forgot anything.
'03GTinFLA
486
St. Petersburg, FL
Oct 31, 2005
  • Oct 31, 2005
You Do Not Need To Capitalize Every Word.
Like stock. Springs are not a must do with stage 1's.
A
ALEX2028
57
  • Oct 31, 2005
if springs are not needed for stage 1s it should just be a matter of removing and installing the new cams??
Hunter-White
162
Jonesboro Arkansas
Oct 31, 2005
  • Oct 31, 2005
Just curious on about how long it takes to pull the 4.6 out and install the cam? I was told by my mechanic it would be an assload of labor to do.
D
Disturbed One
191
  • Oct 31, 2005
There's suppose to be some kind of Cam Follower or cam locker tool to make sure something doesn't rotate on you while the cam is out and throw off timing that you have to get from a dealer. Someone should know what I'm talking about.
stangman
2,690
10
69
in a 3 bed, 2 bath
Oct 31, 2005
  • Oct 31, 2005
well number 1, if your mechanic told you he needed to pull the 4.6 to install the CAM...........run
see if you can tell me where the cams are
Hunter-White
162
Jonesboro Arkansas
Oct 31, 2005
  • Oct 31, 2005
Thank you very much
stangman
2,690
10
69
in a 3 bed, 2 bath
Oct 31, 2005
  • Oct 31, 2005
it's very easy to jump time doing this install. it's best to take it all apart so you can see the timing with your own two eyes, instead of hoping it's right
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Oct 31, 2005
#10
  • Oct 31, 2005
  • #10
I did mine with no experience and had it done in about 12 hours. That includes runs to eat and get more parts.
ocbaud
239
Midwest City, Oklahoma
Oct 31, 2005
#11
  • Oct 31, 2005
  • #11
how hard would it be to do this install at home? what special tools are needed? i've never done any engine work to a mod motor before, always on sbc's in older hotrods. i'm thinking sometime i want to swap cams, but i'm just wondreing how tough it will be.
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Nov 1, 2005
#12
  • Nov 1, 2005
  • #12
I did mine under my carport. Not too hard at all. As long as you have a decent socket set and a pulley puller you would be good to go. But if you go with anything bigger than the Stage 1 you might want to read up on the install and search carefully for the problems some have had. I know a guy who just recently put Comp 270's in his car and bent 2 valves. The tolerances are very close once your go more than Comp 262 or VT Stage 1's.
M
Mel96GT
255
San Diego
Nov 1, 2005
#13
  • Nov 1, 2005
  • #13
The cam install is surprisingly easy IF you have the right tools, follow directions carefully and take your time. The main tool needed is an Anderson Tool or the Ford OEM cam changing tool which eliminate the need to dismantle the front of the engine and/or pull it out. They basically lock the cam chain up by spreading the tensioner apart which allows you to unbolt the cam gear, slide it off the old cam and install the new cam without affecting the cam timing. It is actually a little more involved but you get the idea. I changed out the cams in my '96 GT in a couple afternoons, and I am SLOW. The only thing with your aftermarket cams is to check the timing specs to see it is the same as stock. If not, you will have to re-set the cam timing by pulling off the front covers, etc. There is an article in the June, 2005, issue of 5.0 Mustang about cam swaps w/Anderson tool. Very informative. Good luck.
One more thing, the cam swap thingy tool definitely works on 96-98 and 01-04 GT's but the 99-00 PI engines have press fit cam gears which may prove tricky.
A
ALEX2028
57
#14
  • Nov 1, 2005
  • #14
does anyone have the part number for the ford cam changing tool, also does anyone know if the timing on the vt stage 1s is diffrent form the stock cams, if so will a dyno tune be able to fix this or will it have to be done manually.
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
Foxbody Intro
  • 5.0Sucio
  • May 26, 2026
  • The Welcome Wagon
The Welcome Wagon May 26, 2026
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 9 10 11
5K
Classic Mustang Specific Tech Wednesday at 6:44 PM
DadLife0724
Fox Good shop in Washington state or Oregon
  • keel
  • May 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2026
keel
