cam installation ?'s.
  • Thread starter Thread starter 90lxfoxbody
  • Start date Start date Mar 26, 2006
9
90lxfoxbody
264
  • Mar 26, 2006
i am going to be rebuilding my top end soon. new heads, roller rockers, fresh gaskets, bolts etc etc. i was wondering how complex it is to remove and install a new cam and lifter set. do you have to pull the engine, or can you replace the cam by removing the rad, etc and all the front engine components? also does anyone have a link to a step by step cam installation? thanks.
Modular2v
3,222
23
99
oklahoma
Mar 26, 2006
  • Mar 26, 2006
just removing the radiator will give you enough clearence to slide the cam out. It is a very simple install, to me atleast
legalize420
1,541
South Florida
Mar 26, 2006
  • Mar 26, 2006
you need to slide the condensor up out of the way also. i tried getting a cam out last week and it hit the condensor before i was able to get it out.
RYC CUKR
1,437
Orlando
Mar 26, 2006
  • Mar 26, 2006
Swapping a cam isn't that hard. The worst part is having to pull all of the accessories off of the front of the engine. It can be done in the car. I had to pull my radiator to do the swap but not my condenser iirc.
There are a couple of HCI swap write ups floating around stangnet so you might want to see if you can find one and read up. Pretty straight forward stuff for the most part.
mustangramair
326
Iowa
Mar 26, 2006
  • Mar 26, 2006
I agree with RYC CUKR that the worst part is pulling the accessories. I believe i used 5spdGT's write up on doing the H/C/I swap and it worked great for me.
9
90lxfoxbody
264
  • Mar 26, 2006
thanks for the input. my ac condenser magically disappeared about the same time as all my smog control stuff. i was just standing there, ya know minding my own business and all of a sudden all that stuff just fell off and disappeared. really. does anyone have the link to 5spdGT's writeup. or can i look up his profile and find it?
mustangramair
326
Iowa
Mar 26, 2006
  • Mar 26, 2006
I searched and I found it on this thread, i hope it works. http://forums.stangnet.com/showthread.php?t=583559&highlight=H%2FC%2FI+swap
Modular2v
3,222
23
99
oklahoma
Mar 26, 2006
  • Mar 26, 2006
oh, well, i dont have a condensor
bryce93lx
88
Luke AFB AZ
Mar 28, 2006
  • Mar 28, 2006
This is somthing i don't know about, but at what point do the cam berings on these things wear out, is that somthing that happens often, if it does it may be worth it to take the motor out, i have done it and it really is not all that much more work that other described for the cam install, then you can replace the old motor mounts, and do a rebuild, rings and pistons, and all that stuff is usally under 1000 bucks from and good shop, i got mine for 700, minus the heads and other goodies, just my .02
TheBocSez
652
Converse, TX
Mar 28, 2006
#10
  • Mar 28, 2006
  • #10
Heres another one that pretty good.
http://www.allfordmustangs.com//techarticles/headcamintakeswap.pdf
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
G
Sup. Just got back into the game with a 1986 4-eye vert.
  • GeorgeG
  • Nov 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 7, 2026
limp
For Sale 2002 Mustang GT - 104k Miles, $10k OBO, Las Vegas NV
  • stevetbright
  • Jun 13, 2026
SN95 Mustangs For Sale (1994-04) Jun 13, 2026
stevetbright
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
