Cam Noobie.....Please Help
  • Thread starter Thread starter DocZG
  • Start date Start date Aug 12, 2006
D
DocZG
72
San Antonio, Texas
Aug 12, 2006
  • Aug 12, 2006
OK. I have a couple of questions. I will start out with that i have. 408w based on a 74 Marine block, Mildly ported GT40x, Victor Jr, with 11ish CR, will have a built c6 with a 3200ish stall, and possibly N20 later. I will be using the Comp Cams Hyd Roller conversion lifters....the $440 ones....(cries) I would like to use an off the shelf 5.0 cam because there are so many option. I know they have a different firing order, but i also heard that they have different cam bearing diameter. Does anybody know for sure? and would there be anything else from stopping me?
Assuming that i can use an off the shelf 5.0 cam i need some help choosing what i should get. I know given the engine combo that this will not be a 7500rpm screamer, and thats fine. It will never see above 6k, and i would imagine that with the combo that it would have peak power at about 5500 or so depending on the cam. I wouldnt mind if the idle is rough as long as it doesnt die at the stoplight. It is going to be a strip/cruising/fun car not a DD. I dont know much about cam specs but i know that the heads have peak flow at about .550 lift so i would want something with about that lift.
Thanks
Zach
sms73511
63
  • Aug 12, 2006
TFS stage III
vristang
4,933
101
124
Seattle
Aug 12, 2006
  • Aug 12, 2006
With the strokers you can go with much more duration/overlap than would be acceptable on a 302 motor, so it may be tough to find a cam as large as you will want off the shelf.
I have not looked into the specs yet but Comp Cams XFI stroker series of cams are supposed to be pretty decent.
If you do go with a 302 cam, you'll want one of the bigger ones out there.
jason
R
R2D2
Aug 12, 2006
  • Aug 12, 2006
No such thing as a marine block, then I would have chosen a solid flat tappet custom ground cam instead of spending all that money to run a hyd roller and then stick a lazy off the shelf cam in it. These are just the run of the mill hydraulic link bar lifters right?
Does anyone else have a combo close to this
  • 90Stanger302
  • Dec 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 25, 2025
Qtrhrse23
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
keel
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
