stang_hp Member Feb 25, 2007 62 0 6 cartersville Ga. Apr 29, 2007 #1 Apr 29, 2007 #1 Can anyone tell me if the I will have to position my cam by degreeing, or just stick it in straight up? Im using the Trick Flow stage one in a 331.
8 86bluecobra Advanced Member Dec 20, 2004 4,265 12 69 B.C. Canada Apr 29, 2007 #2 Apr 29, 2007 #2 OK the line is, "you should always degree in a cam." That being said I just stick em in striaght up.
N Npower New Member Oct 15, 2006 16 0 0 Camarillo, Ca Apr 29, 2007 #3 Apr 29, 2007 #3 86bluecobra said: OK the line is, "you should always degree in a cam." That being said I just stick em in striaght up. Click to expand... X2
5spd GT "the 5.0 owns all" Founding Member Aug 7, 2002 9,516 6 99 Arkansas Apr 29, 2007 #4 Apr 29, 2007 #4 Dot to dot is what most would do unless your a perfectionist...like I am That comment probably didn't help... I would stick it in straight up, those cams work just fine at that 'placement'...
stang_hp Member Feb 25, 2007 62 0 6 cartersville Ga. Apr 29, 2007 #5 Apr 29, 2007 #5 Thanks for the info , Im trying to get it to the machine shop so I can hear it run!
