  • 2.3L (N/A & Turbo) Tech
Cam question.
  • Thread starter Thread starter bobbylx
  • Start date Start date Oct 26, 2004
bobbylx
39
  • Oct 26, 2004
Ok, so I want to upgrade my 88 2.3NA to the Ranger Roller cam. I was wondering what else needed to be changed during the process? I need to replace my lifters, so do I need to use the stock ranger lifters or is there another recommended style? Also, I was looking at Racer Walsh and noticed that there are a couple different replacement cam gears. Would I need or get any benefit from an adjustable cam gear? This my first EFI car so I am still learning how to mod it. On my older SBC I would just slap in a new cam and turn the distributor to adjust timing. Anything else I need to consider or replace while I have it stripped down? Thanks
Stinger
7,754
24
118
Basehor (Kansas City), KS
Oct 26, 2004
  • Oct 26, 2004
You just need the cam and roller followers...
You still turn the distributor to adjust ignition timing just like your old 350...the adjustable cam gear is for CAM timing...it's for moving the power up and down in the rpm range...
Stock timing is probably pretty good for a na motor.
mustangkid2.3
344
Piqua, Ohio
Dec 6, 2004
  • Dec 6, 2004
is the ranger roller cam a decent upgrade? what dose it give you, more torque or hp? and is it worth the work?
mr_woodster
1,314
Riverside, CA
Dec 6, 2004
  • Dec 6, 2004
Its a good way to get to know your 2.3 internally. It has its advantages, frees up a little hp and rev's a little easier. I noticed a smother idle when i did mine (read: roller). Its pretty much the stock 2.3 cam except in roller form.
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
Blown88GT
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
M
Pushrod length
  • mattcrp1
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 4, 2025
mattcrp1
M
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
