Cam Recommendations - Comp Xe270hr-12?
Exile
128
Dallas, Tx
I am getting ready to rebuild my motor, and would like to hear some cam recommendations for my built.
I would like to stick with the 1.7 roller rockers for right now...
91' Mustang LX-Hatch (no smog or a/c)
302 (stock bottom end)
GT40 Intake
GT40 Heads
Crane 1.7 Roller Rockers
Crane Beehive Springs
Trick Flow 70mm Throttle Body
Cobra 70mm MAF
24lb Injectors
255lph Fuel Pump
MAC Long Tube Headers
MAC H-Pipe
MAC Pro Dumps
Griffin Aluminum Radiator
MSD Ignition
SR Cold Air Intake
Taurus Electric Fan
T5 with King Cobra Clutch
FRPP Aluminum Drive Shaft
FRPP 3.73 Gears
FRPP 31 Spline Trac Lok
Moser 31 Spline Axles
UPR Upper & Lower Control Arms
UPR Subframe Connectors
I am leaning towards the Comp XE270HR-12 cam (.544 lift), but was wondering if it might be too much cam for my build?
Any feedback is appreciated...
Stock bottom end including pistons?
Can you find a dual pattern cam? I mean the high duration on the exhaust will help.
People will tell you that the cam will be to big on here. The only way to really find out is to throw it in and see.
Do you have the stock cam in it now?
I think it might be a little big if you have stock compression. There's a guy on here trying to sell some KB dome pistons for 120 with the rods. It would be a pretty good investment for a big cam.
The 270hr is a good cam,..or the nx264 35-552-8(I know its a n20 grind but I find they are very efficient and work well on na combos)
Have the heads been milled at all? Was the block decked?
If you decide to go COMP let me know I'll save you some money ;)
Sent from my XT907 using Tapatalk 2
I stick with my recommendations ...your still hovering at around 9:1 compression.
You'll need some valve springs with any of the cams you have listed however to be safe. Let me know when your ready I'll set you up with everything you need.
