cam specs
  • Thread starter Thread starter Cobain03
  • Start date Start date Nov 8, 2005
Cobain03
996
Lexington, Ky
Nov 8, 2005
  • Nov 8, 2005
whats the specs on a stock 289 cam? non hi po.
would switching to a edelbrock performer cam be that much difference?
Edbert
3,548
32
109
Austin TX
Nov 8, 2005
  • Nov 8, 2005
I do not recall the specs offhand but I was AMAZED at how tame they were. IIRC the duration at 50 was around 180-190 for the C-code and lift was about 0.4...simply pathetic!
So yeah, the regular performer cam, although considered an RV grind, WILL wake it up quite a bit, particularly with a decent intake and some small-primary headers.
Cobain03
996
Lexington, Ky
Nov 8, 2005
  • Nov 8, 2005
i have a performer intake as well as tri y's. if the cam would be a good choice then i might as well get the edelbrock performer heads too.
Edbert
3,548
32
109
Austin TX
Nov 8, 2005
  • Nov 8, 2005
If you are willing to spend the money for the heads I'd suggest getting the "RPM" versions.
Edelbrock claims 367fwhp with a 5.0 and the RPM treatment. That is almost twice the stock power
Cobain03
996
Lexington, Ky
Nov 8, 2005
  • Nov 8, 2005
how would the rpm heads work with the regualr intake and cam?
5.0ina66
664
Ohio
Nov 8, 2005
  • Nov 8, 2005
The stock cam is .368/.381 lift, 184/189 dur. & 109LSA. Teeny Tiny! If you want to make power, ditch the Performer intake. A PerfRPM (or a Wieland Stealth), a set of 1.9/1.6 valved PerformerRPM heads and a Comp XE-series cam would do nicely.
Cobain03
996
Lexington, Ky
Nov 8, 2005
  • Nov 8, 2005
keep in mind this car is driven alot! i dont want it stalling at a stoplight (3 speed auto tranny).
5.0ina66
664
Ohio
Nov 8, 2005
  • Nov 8, 2005
LOL...with any of the modern street cams, you won't have any problems like that. I'd use a Comp XE256H or a Comp 262H with those heads and a PerfRPM intake On EA3, it made 355hp & 340tq with an XE256H cam. Not quite to the 367hp advertised, but that's a 302, and you have a 289.
HTH
--Kyle
Cobain03
996
Lexington, Ky
Nov 8, 2005
  • Nov 8, 2005
say i stick with stock heads... which to choose?
steel1212
1,180
Frankfort, Ky
Nov 8, 2005
#10
  • Nov 8, 2005
  • #10
if you stick with the stock heads go with the smaller performer cam. If you pick up the rpm heads get a bigger cam.
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
N
Mods
  • newmex999
  • Oct 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 6, 2026
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
