Cam suggestions
  • Thread starter Thread starter yellow06stangGT
  • Start date Start date Apr 28, 2010
1 of 2 Next Last
Y
yellow06stangGT
11
Wallingford, CT
Apr 28, 2010
  • Apr 28, 2010
Hey guys this is my first thread I am new to this forum...
Well I'm looking to do upgraded cams on my 06 GT, I want something with a little bit rougher idle, I dont mind having to do a Spring upgrade, Dont think I want to have to do a tune right away, maybe something I can install and drive and tune later on. I've looked at comp cams, anyone do any trick flow cams that they would like to talk about? Would like to hear some suggestions or maybe what you have put in your car and how the car responded to the upgrade.
Thanks!
'08GTcaRED
330
Victorville, CA
Apr 28, 2010
  • Apr 28, 2010
Welcome! Glad you could join us here...
First off let me burst your bubble Cams=tune. The computers are just to sensitive in our engines. You will need a tune when you do cams! So if you already have a handheld tuner then just save up 50-75$ more so you can get one or better yet, save up some money for a good dyno tune. Cams are a good way of making a lot of power, but they need tuning!
T
TruBlu03
112
Whitesburg, GA
Apr 28, 2010
  • Apr 28, 2010
FRPP Hot Rods here...awesome choppy/rough idle and a noticeable gain on the top end. They are NSR cams, but like 08GT stated you will definitely need a tune or the car will not run right. BTW, definitely checkout Brenspeeds new "Detroit Rocker" cams.
Here is a crappy cell phone vid of mine:
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf?file=http://vid22.photobucket.com/albums/b345/TruBlu03/Stang/Cams.flv">
ViperNuge
197
Maui
Apr 29, 2010
  • Apr 29, 2010
Daniel is serving popcorn!!!!!!!!!!!!!!! Dude your car sounds awesome.
OP, like the others said you gotta have a tune with cams. You cant even do a cai without a tune with this engine. Well you can but its a pos cai.
I have some detroit rockers headed my way!!!!!! Oh yeah!!
patrick
Y
yellow06stangGT
11
Wallingford, CT
Apr 29, 2010
  • Apr 29, 2010
See my old car was an 86 gt with a 351W and that thing took very well to bolt ons and even the x303 cam, no tune. But when you guys say tune you mean a dyno tune or just one of those tuners off of summit or something.
'08GTcaRED
330
Victorville, CA
Apr 29, 2010
  • Apr 29, 2010
Well we mean an email tune at the very least A handheld like SCT or Diablo with an email tune from a reputable tuner can get you between 30-60 rwhp with cams depending on the cams you get and if you have a CAI to help with airflow.
No doubt the 3v engines love cams, the 3v computers don't
After cams though a dyno tune would be ideal! They can dial it in perfectly, but you will spend more money depending on how much shops charge in your area. Hopefully that helps, if you are still confused or have more questions then just ask!
ViperNuge
197
Maui
Apr 30, 2010
  • Apr 30, 2010
Brenspeed, bama, tillman etc......are the tuners.
patrick
R
Rob72
83
  • May 1, 2010
Check out comp cams 127500
charged07gt
31
  • May 2, 2010
u may want to consider comp cams. they make cams that are nsr (no springs required) that are a direct swap from ur oe cams and require no tuning!! plus they sound pretty good.
chgovfk
531
28
59
AZ
May 3, 2010
#10
  • May 3, 2010
  • #10
I have mutha- thumpr's stage II's and I love them - got the tune from Brenspeed SCT - everything is going pretty good with it - I'm in contact with them on (2) issues - I have blow-by' lockouts - when I first start the rpms really ramp up....and sometimes when slowing down the rpms keep at 3k to 2.5 k after I let off the gas....but then ramp down - plus I have an exhaust smell - that wasn;t there before - anyone have experienced this?...brenspeed is working on a new tune for the ramping....and they just got back to me about the smell - b/c of the mutha thumprs have a controlled 'misfire' built into the cams which can cause all kinds of side effects ....this probably one of them....?
A
ABN_Cobra_03
9
NC
May 6, 2010
#11
  • May 6, 2010
  • #11
Make sure you research the cams and requirements, IE do you need the phaser eliminators and so forth. I am running the Hot Rods and love them, I have installed the Comp stage 2 NSR cams on another 10 GT and he dynoed 4 horse more than me, the downfall is that they have very little lope, which is what you want if I understood your post. The thumpers are good cams too, but require the eliminators. Thats most of the reason I didnt go with them. The detroit rockers are supposed to be good cams also. I am installing a set next week in a customers car. Guess we will see where they set...may be changing out the hot rod cams...LOL
R
Rob72
83
#12
  • May 8, 2010
  • #12
You have to ask yourself one question. Do you want around 330 rwhp or 350 rwhp? You 're not going to get the latter with nsr cams.
Y
yellow06stangGT
11
Wallingford, CT
May 10, 2010
#13
  • May 10, 2010
  • #13
Hey guys thanks for all the input...from what i have been looking at i think i am going to go with brenspeed detroit rockers, and get a SCT X3 tuner from AmericanMuscle.com because when you buy there tuner you get free email tunes for life. Thanks alot, i would still like to hear about everyones Camshaft aftermath.
arcwcb
417
Pennsylvania
May 11, 2010
#14
  • May 11, 2010
  • #14
You need to contact AM, they will only do email tunes for certain cams, before you go that route, make sure the "tunes for life" will actually work with your setup...
bradleyem
186
Columbus, Ohio
May 11, 2010
#15
  • May 11, 2010
  • #15
If you're going to go with Detroit Rockers, then I would definately get my tune from Brenspeed. Since they are a custom ground cam made by Brenspeed, not everyone is going to have the cam profiles to tune it right. Also, if you buy your mods from Brenspeed then I believe that they supply free tunes with them. You just tell them what other mods you have. I have had nothing but great service from them.
Undisputed
306
Westchester County NY
May 11, 2010
#16
  • May 11, 2010
  • #16
R Martin
26
Columbus
May 11, 2010
#17
  • May 11, 2010
  • #17
I had a friend just got his thumper cam done from Brenspeed. When he did his tune from them he went with a dyno tune, yes it cost alittle bit more money but his A/R ratio was right on the money at 12.8. If I am not mistaking I think the dyno tune cost him $350.00 and hearing it from him it was well worth it. Talk to them they will tell what your best way to go.
05Blackstang
clearwater Florida
May 11, 2010
#18
  • May 11, 2010
  • #18
Thanks!
Comp cam thumper is good cam but you have to do a spring up grade. But the detriot rocker cam that Brenspeed offers you don't need to upgrade anything. Now you get the same hp out of both cams, but from what I heard you lose some low torque power with the comp cam but not the detriot rocker cam. I would def get a dyno tune if you do the cam that would be something that I would not wait on. And to be honest I would not trust an email tune for a cam, most people on here may agree with me.
arcwcb
417
Pennsylvania
May 11, 2010
#19
  • May 11, 2010
  • #19
The thumpr cam does not require a spring upgrade, it requires mods to limit or lock out the variable timing.
05Blackstang
clearwater Florida
May 12, 2010
#20
  • May 12, 2010
  • #20
True the comp cam does require 3.73 gears and up as well with delete plates that's for ther stage 2 cam.
1 of 2 Next Last
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
