  • 1994 - 1995 Specific Tech
cam
  • Thread starter Thread starter gtstang86
  • Start date Start date May 23, 2007
gtstang86
55
California
May 23, 2007
  • May 23, 2007
if i want to change my cam on my 5.0, is what all am i going to need to do besides just changing the cam?
sage2k
645
Baton Rouge, LA
May 23, 2007
  • May 23, 2007
timing chain, timing chain gasket, water pump gasket, thermostat gasket
C
cbarr300
746
goose creek, SC
May 24, 2007
  • May 24, 2007
There's a really good sticky with a how-to for h/c/i swap.
realllllly good info in there
fiveoho
1,958
TN
May 24, 2007
  • May 24, 2007
of course, as you know, you do not get the performance gains to justify the amount of money spent. just a cam probably will not net you any horsepower and if so, probably not much. it will also have to be a very mild cam especially if you want to run stock springs ( some guys say you can , some say change them ). also, your stock computer will more than likely not like the cam change ( ie. surging, stalling, bucking ). some 94/95 guys get lucky with the computer and some dont. several guys have done a swap to a A9L fox body computer for better idle quality and manners ( our stock computers are supposedly better , just require more tuning ).
not trying to discourage you from camming your. i also want to cam and intake my 95 but i know my gains will be minimal with my stock heads.
some things you will need was posted above. also might want to consider a new waterpump, especially if you are still running the stock one ( probably time for it to crap out anyway ). good time to change out the harmonic balancer if the one on the car is coming apart. as said, a timing set & gasket. wp gasket. maybe new lifters, might want to ask other guys here about that. surely you can use your factory rockers. springs?
cam swap may soften up the bottem end so a steeper gear would counter that.
which cam was you thinking about going with?
gtstang86
55
California
May 24, 2007
  • May 24, 2007
well i figured i would probably have to get a chip. i would probably just have jet burn me one. if i could get better performance with just a cam id go with a ford racing setup but since it sounds like im going to need more so i was think of trick flow's twisted edge kit with the valve train, heads, and intake manifold. id probably have to bump up to the 24lbs injectors too.
fiveoho
1,958
TN
May 24, 2007
  • May 24, 2007
TFS kit def makes good power. usually close to 300rwhp with bolt ons
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Y
Dash cam
  • yankeyfan02
  • Sep 15, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 18, 2026
horse sence
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
