cam
of course, as you know, you do not get the performance gains to justify the amount of money spent. just a cam probably will not net you any horsepower and if so, probably not much. it will also have to be a very mild cam especially if you want to run stock springs ( some guys say you can , some say change them ). also, your stock computer will more than likely not like the cam change ( ie. surging, stalling, bucking ). some 94/95 guys get lucky with the computer and some dont. several guys have done a swap to a A9L fox body computer for better idle quality and manners ( our stock computers are supposedly better , just require more tuning ).
not trying to discourage you from camming your. i also want to cam and intake my 95 but i know my gains will be minimal with my stock heads.
some things you will need was posted above. also might want to consider a new waterpump, especially if you are still running the stock one ( probably time for it to crap out anyway ). good time to change out the harmonic balancer if the one on the car is coming apart. as said, a timing set & gasket. wp gasket. maybe new lifters, might want to ask other guys here about that. surely you can use your factory rockers. springs?
cam swap may soften up the bottem end so a steeper gear would counter that.
which cam was you thinking about going with?
well i figured i would probably have to get a chip. i would probably just have jet burn me one. if i could get better performance with just a cam id go with a ford racing setup but since it sounds like im going to need more so i was think of trick flow's twisted edge kit with the valve train, heads, and intake manifold. id probably have to bump up to the 24lbs injectors too.
TFS kit def makes good power. usually close to 300rwhp with bolt ons :nice:
