90Ranger, you're also running a Bullit intake with Stage I cams. Not the stock intake setup with Stage II cams. The Bullit intake helps to pick torque up on the low end and improve throttle response over the stock intake. That, and the Stage II cams have a bit more lift for higher rpm band power than Stage I's. Not saying its a "world of difference" from your setup, but different none the less.
