Cams???
A questions about camshafts.... i know nothing about them... ive heard they help quite a bit and have been recommended to get em in my car... but it seems like everywhere i look they are only availabe for 5 speeds.. so this is my question.. is it possible to put cams in an AOD????
Camshafts can be put in any car, if you provide more info on your car, people can give better recommedations. There are several factors in choosing which one, if you need one at all. I am having a custom cam made for my AOD car right now.
they recomend certain cams for 5 speeds because 1, bigger cams usually sacrifice some bottom end which you don't want with a stock aod, or any auto for that matter, and 2 the lopier idle doesn't agree well with stock stall converters......the converter needs to be looser at idle so the car won't have a tendancy to die or stall in gear when stopped...
Man, this list comes in handy....
Your first mods should be as follows (my take):
In order of Priority
1) Subframe connectors (SFC's) full length ones are prefered for a stiff chasis
2) Gears: 3.73:1 or 4.10:1 seem to be the popular choices and should be the first modification
3) Buy a K&N panel filter (no CAI kit required) and put it in the stock box
4) Exhuast (headers, hi-flo cats, mufflers)
5) 3G alternator upgrade / electric fan
6) Larger MAF, TB (MAF cars from 1988 california only, 1989-1993)
7) Fix the weak brakes
8) Bumped timing (free mod) 10 Degrees is stock.
After those, it's pretty much up to you. There are plenty of Super Chargers or Heads, Cam and Intake packages to choose from. But at this point modification becomes very expensive so plan wisely.
Also, don't forget about the basic tune up which should include:
1) Changing all of the fluids (oil, coolant, trans, rear end, brake and some of the power steering)
2) Plugs: (non-platnum type) Autolite or Motorcraft
3) Oil filter: Motorcraft or equivalent (not FRAM)
4) Air filter: see above
5) Plug wires: Ford Motorsport (FRPP) 9mm units are great
6) Cap / Rotor
7) Oxygen sensors
Note: I leave U/D pullies off of the list as a first modification. Sometimes the gains obtained are usually offset with the charging issues that occur.
Do that list, it works. And a bigger cam in a stock engine is a waste of money, its like you trying to breath through a drinking straw. Get heads, exhaust, intake and a converter to match along with some rear gears. Then worry about getting cam.
