  • SN95 4.6L Mustang Tech
Cams??
  • Thread starter Thread starter Silverstang02GT
  • Start date Start date Mar 11, 2009
1 of 2 Next Last
Silverstang02GT
60
Ft. Myers FL
Mar 11, 2009
  • Mar 11, 2009
what cams do you guys think would work well with my set up. I was thinking about going with Comp Cams Stage II Xtreme Energy XE270AH Camshafts and the Comp Cams Valve Springs Kit Beehive.
I have the Professional Products Typhoon Intake Manifold, C&L 80mm MAF, 75mm TB and Plenum (acufab), BBK shorty headers and O/R X pipe, 2 chamber flowmasters and 3.73 gears. there are some other mods but thats it as far as air flow.
thanks
evil281
276
Arizona
Mar 11, 2009
  • Mar 11, 2009
gona stay n/a or ever gona put a blower on there?
Silverstang02GT
60
Ft. Myers FL
Mar 11, 2009
  • Mar 11, 2009
my feelings at this point is to stay N/A. both for cost and the car has high miles
evil281
276
Arizona
Mar 11, 2009
  • Mar 11, 2009
i have no idea on if thats a good cam or not but just to get that info out there since everyone else is gona ask too
crazystang25
492
  • Mar 12, 2009
for N/A i would suggest the stage 2 hitechs. i gotta buddy thats runnin the comp 270's and he suggested the same also. comps are great, but the hitechs are just a better N/A cam. and springs are not required with these ones either. they are recommended if you plan to push it over 6400 rpms though.
blksq10psi
114
PHILLY
Mar 13, 2009
  • Mar 13, 2009
i heard vt cams sound pretty bad s**
crazystang25
492
  • Mar 13, 2009
either way comps and the hitechs both sound B/A i have heard both but as far as N/A goes i would still do the hitech stage 2's. if you planned on boostin later either would be good.
Cobra123089
94
Broomfield CO/ Laramie WY
Mar 13, 2009
  • Mar 13, 2009
i would go hitech stage 2's. When i did my cams hitech was nt well know. My 270's are a decent nitrous cam anyways
MaxedGT
304
Surrey BC Canada
Mar 14, 2009
  • Mar 14, 2009
If you're car is strictly for street use a stage 1 comp cam would be a wise choice. For the street you don't want to lose the low end torque. The xe262ah would be my choice. Most stage 2's increase power above 5800 rpm but are you going to rev that high?
Dark_Horse
83
Springfield, MO
Mar 15, 2009
#10
  • Mar 15, 2009
  • #10
+1 on the hitech stage 2's...its probably the best n/a cam you can get without ptv clearance issues
J
jcklee43
20
Beaverton
Mar 15, 2009
#11
  • Mar 15, 2009
  • #11
I have the Comp Stage II Cam and love it. Great power gains and very street able. I didn't see what gears you have, but I have 3.73 and didn't feel like I lost any on the low end. You will want 3.73 or 4.10 with stage II Comp Cams in my opinion.
N
ninjastang125
591
maryland
Mar 16, 2009
#12
  • Mar 16, 2009
  • #12
vt cams are now made by cushman motorstorts.i heard they are badass cams. i am awaiting on the install on mine. heres the linkCMS Stage 1 N/A Cams - $559.55 : Zen Cart!, The Art of E-commerce
Dark_Horse
83
Springfield, MO
Mar 17, 2009
#13
  • Mar 17, 2009
  • #13
Does anyone have the VT stage 2's? I'm wondering about them because they have a pretty agressive idle but the description says it's a good all around street/strip cam. They sound damn mean. I see that the valve lift is 560 and 575, I wonder if they have clearance issues
crazystang25
492
#14
  • Mar 17, 2009
  • #14
not sure about ptv issues with the vt's i havent heard a whole lot on them just a little bit on here, not bashing them by any means so dont take it that way. but i havent heard of any ptv issues with the stage 2 hitechs. with the higher lift vt's you might run into some. have to make sure the cams are degreed perfectly especially if you increase the compression. other wise you will be doin it all over again.
CobraRed_96_GT
1,421
UCSD/La Jolla
Mar 17, 2009
#15
  • Mar 17, 2009
  • #15
They have 0 clearance issues, it's not all about lift. My cams have .567 lift.
98GTfromGA
291
Memphis
Mar 17, 2009
#16
  • Mar 17, 2009
  • #16
i would say the Hitech stage 2s or the Comp 270s
navarro98gt
213
chicago, IL
Mar 18, 2009
#17
  • Mar 18, 2009
  • #17
I’m running CMS (formerly VT) Stage 2 cams with PI heads and no ptv issues.
M
Midnight2V
224
Oklahoma
Mar 18, 2009
#18
  • Mar 18, 2009
  • #18
I have had the Comp xe270ah in my car for about 4 years now in both NA and supercharged form, so I can speak of their performance. I will not speak on any other cam except to compare it to the PI set I had before. The reason I have had it for four years is because I have yet to find a better cam for MY particular setup.
I have a built, stock displacement, ported SVO heads/Intake combo and these cams really woke it up. They make more power over the PI set in every part of my dynograph (2500-7000rpm). The power did not peak until 6300 in naturally aspirated form. I was getting 325rwhp, and 345 peak torque at around 4600rpm. I had all the other assorted bolt-ons. Torque was well over 300 from 2400 rpm until well past 5500. I would shift at around 6700. If i remember right, i was running around 19-21 degrees of total ignition timing on 91 octane gas.
As you can see, these cams make fantastic peak torque. In fact they make more peaktorque than either the xe262ah and the xe278ah by Comp Cams own admission. You may gain some significant power by going to the 278ah if you go past 7000. I don't know.
These cams do even better in supercharged form. This is due to the larger LSA and the longer duration on the exhaust valve compared to the intake. In NA, a little more duration on both intake and exhaust combined with a smaller LSA would probably yield a little better power, but at the expense of torque.
Designing a cam is a game of give and take. Ask yourself this, what do you want the car to do? Have a peak power number you can impress all your friends with , or a nice wide powerband you can develop a great big smile with while you move through it. Sure you can find a cam that is going to make more peak power, but at what cost? I don't want to run around having to run 4800-7000 just to make power on a cam....especially in NA form.
Instead of looking for peak power, you may want to look for power under the curve. Whether or not the HItech stage 2 meets this description is unknown to me because I went PA before they were ever released, and so I never got to race a HiTech equipped car, let alone on equal footing. A great example of power under the curve vs peak power is the 2001 cobra rated at 320 hp compared to the 2003 Mach 1 rated at 305 hp. The mach 1 made more power under the curve despite a lower peak value. This has been proved many times on the dyno, and more importantly, at the track.
As far as lift is concerned, It seems that all the 2V heads do not make significant flow increases beyond .550", ported or not. Comp realized this and that is why they stressed ramp rates instead of peak lift in their design. Their design allows the valve to be at a much larger average lift accross the cycle compared to many designs. What good is a peak lift if you are only at it for .025 degrees of your crank cycle when the piston is at bdc and hardly moving? Remember, the valve that opens to .600" also has to close .600". That means more energy losses in the valve train for minimal gain.
I hope this helps you with your decision. I only throw my 2 bits out there because I have seen lots of guys with better peak numbers than my own who are infuriated when I outperformed them. I just do not see the merit of gaining a few HP in a very narrow area at the expense of a lot of torque over a wide part of the RPM range. Remember it is your rig. You do what you want and never mind what anyone (including me) tries to tell you. Find out for yourself.
crazystang25
492
#19
  • Mar 18, 2009
  • #19
+1 as i said i have run neither just seen what both can do. still debating myself which to go with. both are great cams IMO.
scupking
1,186
Enfield, CT
Mar 18, 2009
#20
  • Mar 18, 2009
  • #20
Best N/A cam would be the hitech stage IIs. I will be putting them in sometime in the next month or so.
1 of 2 Next Last
I
Engine Insane fuel trims +25% LTFT Bank 1, -16% LTFT Bank 2
  • imw_stl
  • Aug 31, 2025
SN95 4.6L Mustang Tech Sep 19, 2025
Mustang5L5
M
My numbers sound right?
  • MiltP
  • Feb 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 2, 2026
MiltP
M
P
New member with 98
  • Poster
  • Apr 28, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 8, 2025
Poster
P
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
