Can a stock 94 5.0 handle a blower
I will be adding a supercharger to my stock bottom end with the mods I have in my sig, plus a cam. I have seen a lot of guys go up to 10# of boost from blowers on the stock blocks (non-intercoolerd) but you have to make sure you upgrade your fuel system and igntion. If you are completely stock, I wouldn't put a blower on first. I would do gears, exhaust and other bolt ons first before i put a blower on. Hope this helps some.
Hey there, I've got a Vortech S-trim on a stock 95 Cobra engine, and it's been quite impressive. The weak link will be your stock pistons though. Make sure you get the ignition module and adjust your air/fuel to be sure it's not too lean. Preingnition and/or running lean will shatter the stock pistons. Also, make sure you're venting the crankcase or you'll "blow a seal".
Im more worried about headgaskets, im running 11-12 on all stock except the intake manifold and some felpro gaskets.
AIRRIDE said:
Can a stock 94gt handle a blower and how much booost can it handle to be still safe.thanks.
Yep.
As for boost, that is not a good way to measure. On a 100% stock setup, I would expect that you would see 15 to 20 psi of boost before breaking anything. The weakest part of the engine is the block itself, and it should handle upwards of 500 horsepower. But I think I'd aim for 400 to 450 rwhp to keep good reliability.
What's really important is the tune. A bad tune will kill even the stoutest motor dead. Lucky for us, the 5.0 is likely to blow a headgasket with a bad tune before it actually destroys any parts.
Dave
