exactlyGreen 94 5.0 said:if you are going to use a predefined MAF transfer, you need to use the one that matches the calibration od the meter. from your other thread, that would be the PROM_19 calibration.
Pokageek said:Ok thanks man. Last question..does anyone have a link to a wiring diagram for the stock MAF sensor telling which color wires are which and why it matters whether you are running CAI or not or how that effects calibrations?
I have basically got to decide between 2 meters. I bought a granatelli 75mm MAF..they sent me a 90mm but at least it is calibrated for 24# injectors. It has no spec sheet but can use the original wire connector that came with the car. Says it is calibrated for CAI too.
Brothers sent me a new 75mm MAF that is properly programmed for 24# and has a spec sheet but has a different connector that has to be spliced into the old MAF wiring. Doesn't say if it is or isn't calibrated for CAI.
