can I run boost
Gearbanger 101
Straight Outta Locash
9,457
1,378
234
Ontario, Canada
You shouldn't have a problem with 5-8psi provided its tuned conservatively enough, your fuel system is up to snuff and you run the highest octane fuel available in the tank at all times. Personally though...with that kind of compression, I might be more likely to run a little nitrous with that combination instead.
tannerc91gt
This last 25% is foreign territory at this point
2,977
234
Indiana
+1
boosting it would be pretty expensive also considering getting a tune and making sure everything else is up to par and then only being able to go so high with boost.
you would actually be safer (or at least simpler) IMO to put a little juice to it :nice:
foxmustangman
196
Idaho
For the low boost you'll have to run to keep your engine from exploding wouldn't be worth the cost of buying the supercharger. Unless you got it for free of course.
I'd even be leary of 8lbs though, i'd say 6 at the most with 11:1.
+1 on juicing it :D
Gearbanger 101
9,457
1,378
234
Ontario, Canada
Roughly your gain is somewhere around 10 HP per pound of boost. Roughly.
I would bet that with the decent combination of top end parts, the added displacement and his higher compression ratio, gains would be closer to 15hp per.
I wouldn't be too concerned with blowing anything up with a little boost either. I'm assuming that since it’s got a bore over and the pistons were replace, you replaced them with forged, or at the very least decent hypereutectic slugs, did you not?
In which case, the pistons should hold up. What usually pukes first when boosting a 302 with compression is the head gaskets because of the inferior and inconsistent clamping force of its 7/16" head bolts that allow the head to distort under pressure.
...but since you're working with a 351W that has stronger 1/2" head bolts, you're not likely to experience that issue.
As I stated....5-8psi (which is really going to depend on pulley size and flow capabilities of your top end and exhaust....so don't just use boost figures as your guide) with conservative timing and generous fuel curves your engine could easily handle a little forced induction and would reward you with some decent gains.
I recommended the nitrous because quite frankly nitrous will be the cheaper set up (provided you're not going through a bottle a day) and compression is actually a welcomed advantage when spraying.
In any case, if you cheap’d out on build components like pistons, bolts/stude, or head gaskets, etc and aren't sure about fuel system suporting components (injectors, pump, fuel lines, etc)....then you limit your engines capability to handle power. It doesn't matter which power adder you're using. In any case a compitent dyno tune is going to be a must for either set up. No half assing it with FMU's.
