Can I use a polyester finishing putty or a filler on a urethane front bumper?
I have a spot, probably around 1.5 inches wide, and like 3-4 inches tall where the urethane on my bumper dips down slightly and is noticeable when sanding. Can I use a polyester finishing putty on this or a filler on it? It is urethane and will be flexing slightly. What should I put on it before I put the filler?
copied from MSTANG
Automotive Aftermarket
Truck Line EZ Sand Flexible Parts Repair
08276, 400 mL, 6 per case
Two-part epoxy used to repair most plastic parts, including bumper covers, and other plastic body panels (not for use on SMC/fiberglass). Use 3M™ Polyolefin Primer 05907 for system II plastics. 10 minute work time, 30 minute sand time, 4 hour cure time
Buyer's Part Number : 08276
GTIN(UPC/EAN) : 0 00 51135 08276 8
3M Id : 60-9800-3708-3
ADDITIONAL INFORMATION
Automatic mixing. Designed to be used as a filler and adhesive. Epoxy based for easy sanding. Formulated for excellent feather edge.Flexible through a wide range of temperatures.
CHARACTERISTICS
Clamp Time
1 Hour
Color
Gray
Cure or Dry Time
4 Hour
Work Time
10 Minute
3M 1995-2001
I had asked that question earlier and didnt get the answer I was looking for.
But I found it today at a Auto Body Shop supply store.
Its called REMOV ALL Stripper, it comes in a spray can and it states that it works on all of the normal metal surfaces and also works on TPO Bumpers, Rubber Seals. I have not used it yet but I thought I would find my old Thread and add this info to it. In looking for my thread I found yours.
I have used a soft epoxy (2-part) on the bumper before.
I can't remember the name of the stuff, but it worked great.
It's been in the front bumper for several years, no issues.
I'll see if I can find the stuff next time I'm in the parts store...
jason
