cant get fuel regulator to stop leaking
Black70Fastback
319
Dyer, IN
the stock one pees out fuel and so does the bbk. what should i do? i even tried it with that rubber gasket thing bbk gives me.
also does any one know it the bbk is set at 39 pounds already or is it not set at all out of the box?
you know there is more than one o-ring on the regulator,
there are two on the part that stick down into the fuel rail, and one that goes and sits flush with the rail to the other part...........poorly explained i know.....
jason
ok i tried to type this twice last nite but it kept gettin deleted :bang:
the bbk should come with new o rings, mine did
also, it comes with a flat gasket which u shouldt use unless the stock one utilizes one.
when i did my regulator, i tightened the threaded insert on the regulator for the fuel pressure guage to much and fuel leaked from there :bang: . i just loosened it and instead of cranking it down, hand tightened it. hope this helps, kyle
