Background:
The engine has been together without much change since 2000. The previous best dyno results were in February of 2002, which were 498 hp and 455 lb/ft at the wheels (dynojet). The combo at that time was:
Stock 92 shortblock and cam
Vortech S-Trim Supercharger with 2.95" Pulley (16 psi @6000 rpm)
ASP 7" Crank Pulley
Edelbrock 6037 Aluminum Cylinder Heads
Trick Flow “Street” Intake Manifold
FRPP 65 mm Throttle Body and Spacer
Pro-M 80 mm MAF with Conical Air Filter
Dynotech "Boostmaster" 4" Inlet Pipe
Crane “Cobra” 1.7 Roller Rocker Arms
FRPP 42 lb/hr Fuel Injectors
Crane HI-6R Ignition with TRC-2 Boost Retard and PS91 Coil
Autologic mail order chip by JMS
FRPP 1 5/8" SS Shorty Headers
Bassani 2 1/2" Catalytic X-Pipe
Dynomax 2 1/2" Super-Turbo Cat-Back Exhaust
Since that time (recently) I had converted from the 7"/2.95" blower pulley set up to a 8"/3.33" renegade set up that gave me the same boost numbers up top but did a lot to stop belt slippage. I had also ditched the JMS chip and gone to a homebrew tune with the timing retard. Ended up getting a minor head gasket leak after a tank of bad gas in April, so it was time to pull it apart.
While apart, I went ahead and had the non-hardened spring seats on the 6037's heads replaced with hardened ones, had a good valve job done, replaced the seals, cleaned up the surfaces, polished the chambers, and added a new set of Crane springs and retainers. In putting it back together I swapped out:Crane 2031 cam for stock cam, FRPP ceramic coated shorty headers for FRPP non-coated shorties, New double roller timing chain set (old was was really stretched).
Got it all back together on Saturday 5/13 and took it to Atlanta Chassis Dyno on Monday (5/15) to have it tuned with a new chip. Brad Brand did the tuning using the SCT chip and software. We made a total of 9 pulls in getting the tune set up right.
The red run is the baseline pull made when I first arrived. It made 479/441 on that pull but was very rich (way less than 10 to 1) through the middle rpms. Brad then put a baseline program from another supercharged fox on the chip and began making pulls and tweeking the MAF enrichment table. Eventually getting it to a point where it was 11.5 to 1 at the torque peak and 12.1 to 1 at max boost. The results were 525/480 (blue run). We buttoned it up and took it for a drive to make sure there were no drivability problems.
The car is faster than it has ever been. Looking at the curves we picked up 45/38 at peak, but the real story is in the mid rpms where were able to pick up around 70hp/100 ft/lbs between 4000 and 5000 rpm. That translates into incredible grunt. It has never pulled this hard above 3500 rpm. Right now it seems scary fast, but I am sure I will get used to it. Finished up by taking it to have it's annual emissions test, which it passed fine.
Now hopefully I can enjoy it for another 6 years while I save up for a dart block to replace the stocker.
ASP 7" Crank Pulley
