Car bucking under decelleration/coasting
Brando 91LX
36
The car bucks under decelleration/coasting when it is in any gear (t5), but not in neutral. Definitely feels like a driveline issue..clutch maybe. I just put the car back together-new motor, clutch etc...Any ideas?
What is the timing set at? Did you install a cam or anything when you put the motor back together? Does the bucking happen at lower rpms...say below 1500? Be a little more specific.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
index.php
index.php
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
attachment.php
89 through 95 cars have a working Check Engine light. Watch it instead of a test lamp.
attachment.php
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Look for codes 27 or 29. Post whatever codes you get & I will try to help.
My money's on it being an EGR-related issue.
Check all vacuum lines for leaks/breaks/dry-rotting. Spend a buck or two on a new EGR valve gasket, pull that puppy off, and start reaming all the built-up carbon gunk out of there. Make sure the valve will hold vacuum (push in the plunger, put your thumb over the vacuum nipple, let go, see if you can feel the vacuum on your thumb - it'll make a "ttthhhuck!" noise when you pull your thumb off) to verify that the diaphragm is still good in it.
Oh yeah ... and pull the codes, too. :)
