Car computer trouble codes!
  • Thread starter Thread starter amplifier28
  • Start date Start date Jul 24, 2005
amplifier28
222
  • Jul 24, 2005
I have a 1988 Mustang GT with mass air conversion. My car has a functional ram air hood from Cervini's called the 2.5" Stormin Normin hood. My car also has a BBK 70 mm throttle body and Cobra Intake. Anyways, I hooked up a code scanner for OBDI car computers. I scanned it with "key on and engine off". I received a "81" code. The manual for the scanner says that the code means the following:
"Air diverter solenoid fault, intake air control circuit fault / air injector diverter"
What does this mean? What should I fix or replace to correct this problem?
By the way, the car works fine, but sometimes shuts of when the air conditioner is on and I shift into park. Information greatly appreciated. Thanks in advance.
amplifier28
222
  • Jul 24, 2005
Any suggestions?
HISSIN50
34
129
Jul 24, 2005
  • Jul 24, 2005
That is a code for the smog pump IIRC. Seems to me it is the secondary divertor valve. It is buried behind the pass fender as I recall.
Jrichker has a nice write up about this code and how to test it, etc.
Good luck.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 24, 2005
  • Jul 24, 2005
Code 81 – Secondary Air Injection Diverter Solenoid failure AM2. The solenoid valve located on the back side of the passenger side wheel well is not functional. Possible bad wiring, bad connections, missing or defective solenoid valve. Check the solenoid valve for +12 volts at the Red wire and look for the Lt Green/Black wire to switch from +12 volts to 1 volt or less. The computer controls the valve by providing a ground path on the LT Green/Black wire for the solenoid valve.
See http://www.veryuseful.com/mustang/t...ng5.0Vacuum.gif for help on the vacuum line plumbing.
Euphoric306
905
  • Jul 25, 2005
are you god?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 25, 2005
  • Jul 25, 2005
BlahBlahson said:
are you god?
NO way.
See Ford Fuel Injection & Electronic Engine Control 1988-1993 by Charles Probst :ISBN 0-8376-0301-3. for Ford EFI help. When you know how it works, troubleshooting is much simpler.
It's about $20 from Borders.com see http://www.amazon.com/ . Select boo...very good, and I found it to be very helpful.
amplifier28
222
  • Jul 25, 2005
The link does not work. What gives?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 25, 2005
  • Jul 25, 2005
Copy www.amazon.com into your broswer address bar. Then the link works good. If there is a Borders bookstore in your area, they can get the book using the ISBN number.
amplifier28
222
  • Jul 25, 2005
The following link does not work:
C
Engine Code 94 and 13
  • CmdrDerp
  • Nov 3, 2024
Fox 5.0 Mustang Tech Nov 4, 2024
AeroCoupe
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
