Car Cut Off , Ignition Switch ?
  • Thread starter Thread starter Killa
  • Start date Start date May 15, 2014
  • 3
  • 4
  • 5
First Prev 4 of 5 Next Last
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 20, 2014
#61
  • May 20, 2014
  • #61
Helpful hint: Use regular machine screws when you put the TFI back on. I think that they are 8-32 SAE (ordinary American) thread.
I have used a 1/4 drive, thin wall 1/4" deep socket to remove the original screws.
Killa
1,006
56
49
May 20, 2014
#62
  • May 20, 2014
  • #62
so you guy 99% sure my problem is the TFI ?
old_blue
1,783
282
124
May 20, 2014
#63
  • May 20, 2014
  • #63
Could be a lot of different things. I had to replace my whole dizzy due to a broken piece inside it. It caused really bad idle problems and cutting off while driving down the road.
Killa
1,006
56
49
May 20, 2014
#64
  • May 20, 2014
  • #64
order one and the tool from LMR , just did a search and found this is common problem,, if it not fix, good to have it on hand.
Killa
1,006
56
49
May 22, 2014
#65
  • May 22, 2014
  • #65
the new sensor came in the mail today, with that special tool. Gonna install it tonight and hope it fix the problem.
Killa
1,006
56
49
May 23, 2014
#66
  • May 23, 2014
  • #66
quick update : Install the new TFI today, run fine, until I get to the stop light and it cut off.
old_blue
1,783
282
124
May 24, 2014
#67
  • May 24, 2014
  • #67
Could be a couple different things. Did you pull error codes? I dont remember.
Killa
1,006
56
49
May 24, 2014
#68
  • May 24, 2014
  • #68
not yet, I order a code reader last week, it support come this week, mabe tomorrow.
btw the idle is hang a 2-3 second before it going back down to 1k, for example if I rev the car up to 3k while idle, it stuck at 1.5k for 2-3 second before it go back down to 1k.
old_blue
1,783
282
124
May 24, 2014
#69
  • May 24, 2014
  • #69
What year again? Also, did you go through jrichters chklist?
You dont need a code reader to pull codes. I think jrichter already posted how to do that. Very easy to do.
Killa
1,006
56
49
May 24, 2014
#70
  • May 24, 2014
  • #70
its an 89 mustang 5.0 LX automatic
89oem
Mustang Master
Dec 18, 2013
1,456
542
144
May 24, 2014
#71
  • May 24, 2014
  • #71
use j's list.. save money and time.. you can count the check engine light blinks... same as using the code reader.... follow list from to bottom.. you will find the issue and maybe ones you were unaware of as well...
Reactions: tamadrummer88
Killa
1,006
56
49
May 31, 2014
#72
  • May 31, 2014
  • #72
sorry guy, been really busy this week, the code reader came couple day ago, finally have some time this afternoon to plug it in.
It gave me these code, the code reader flashing and it give me these random number, the last number is just solid
34
85
10
34
car hard to crank when it hot out side,
car random cut off while wait at the redlight , take 2-3 try before it crank back up
the idle stuck at 1.5k for 2-3 second before it go back down
my only concern its, cut off while wait at redlight.
Killa
1,006
56
49
Jun 9, 2014
#73
  • Jun 9, 2014
  • #73
up
FoxMustangLvr
I love my Pimp
SN Certified Technician
Oct 14, 2012
4,968
3,514
204
Spokane, Wa
Jun 9, 2014
#74
  • Jun 9, 2014
  • #74
Have you or have you NOT tried the surging idle check list?
You're working hard at avoiding it but you seem to try very hard at making things more difficult than they really should be, example...not answering a very simple question from @madmike1157 about what country you're from and instead you went into your income, profession, how much you paid for your house, mopeds and all that other bull that nobody cares about. Your English sucks and it makes it difficult to COMMUNICATE.
Do the process of elimination. Do the surging idle checklist! Start at #1.
Welcome to "American" , some of my Family came from Portugal.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 9, 2014
#75
  • Jun 9, 2014
  • #75
34
85
10
34
The only significant codes are the 34 & 85
Code 34 Or 334 - EGR voltage above closed limit –
Revised 26-Sep-2011 to add EGR cleaning and movement test for pintle when vacuum is applied to diaphragm
Failed sensor, carbon between EGR pintle valve and seat holding the valve off its seat. Remove the EGR valve and clean it with carbon remover. Prior to re-installing see if you can blow air through the flange side of the EGR by mouth. If it leaks, there is carbon stuck on the pintle valve seat clean or, replace the EGR valve ($85-$95).
Recommended procedure for cleaning the EGR:
Conventional cleaning methods like throttle body cleaner aren’t very effective. The best method is a soak type cleaner used for carburetors. If you are into fixing motorcycles, jet skis, snowmobiles or anything else with a small carburetor, you probably have used the one gallon soak cleaners like Gunk or Berryman. One of the two should be available at your local auto parts store for $22-$29. There is a basket to set the parts in while they are soaking. Soak the metal body in the carb cleaner overnight. Don’t immerse the diaphragm side, since the carb cleaner may damage the diaphragm. If you get any of the carb cleaner on the diaphragm, rinse it off with water immediately. Rinse the part off with water and blow it dry with compressed air. Once it has dried, try blowing through the either hole and it should block the air flow. Do not put parts with water on them or in them in the carb cleaner. If you do, it will weaken the carb cleaner and it won’t clean as effectively.
Gunk Dip type carb & parts soaker:
If you have a handy vacuum source, apply it to the diaphragm and watch to see if the pintle moves freely. Try blowing air through either side and make sure it flows when the pintle retracts and blocks when the pintle is seated. If it does not, replace the EGR.
If the blow by test passes, and you have replaced the sensor, then you have electrical ground problems. Check the resistance between the black/white wire on the MAP/BARO sensor and then the black/white wire on the EGR and the same wire on the TPS. It should be less than 1 ohm. Next check the resistance between the black/white wire and the negative battery post. It should be less than 1 ohm.
Note that all resistance tests must be done with power off. Measuring resistance with a circuit powered on will give false readings and possibly damage the meter.
Let’s put on our Inspector Gadget propeller head beanies and think about how this works:
The EGR sensor is a variable resistor with ground on one leg and Vref (5 volts) on the other. Its’ resistance ranges from 4000 to 5500 Ohms measured between Vref & ground, depending on the sensor. The center connection of the variable resistor is the slider that moves in response to the amount of vacuum applied. The slider has some minimum value of resistance greater than 100 ohms so that the computer always sees a voltage present at its’ input. If the value was 0 ohms, there would be no voltage output. Then the computer would not be able to distinguish between a properly functioning sensor and one that had a broken wire or bad connection. The EGR I have in hand reads 700 Ohms between the slider (EPV) and ground (SIG RTN) at rest with no vacuum applied. The EGR valve or sensor may cause the voltage to be above closed limits due to the manufacturing tolerances that cause the EGR sensor to rest at a higher position than it should.
The following sensors are connected to the white 10 pin connector (salt & pepper engine harness connectors)
This will affect idle quality by diluting the intake air charge
Code 85 - CANP solenoid - The Carbon Canister solenoid is inoperative or missing. Check vacuum lines for leaks and cracks. Check electrical wiring for loose connections, damaged wiring and insulation. Check solenoid valve operation by grounding the gray/yellow wire to the solenoid and blowing through it.
The computer provides the ground for the solenoid. The red wire to the solenoid is always energized any time the ignition switch is in the run position.
Charcoal canister plumbing - one 3/8" tube from the bottom of the upper manifold to the rubber hose. Rubber hose connects to one side of the canister solenoid valve. Other side of the solenoid valve connects to one side of the canister. The other side of the canister connects to a rubber hose that connects to a line that goes all the way back to the gas tank. There is an electrical connector coming from the passenger side injector harness near #1 injector that plugs into the canister solenoid valve. It's purpose is to vent the gas tank. The solenoid valve opens at cruse to provide some extra fuel. The canister is normally mounted on the passenger side frame rail near the smog pump pulley.
It does not weigh but a pound or so and helps richen up the cruse mixture. It draws no HP & keeps the car from smelling like gasoline in a closed garage. So with all these good things and no bad ones, why not hook it up & use it?
The purge valve solenoid connector is a dangling wire that is near the ECT sensor and oil filler on the passenger side rocker cover. The actual solenoid valve is down next to the carbon canister. There is about 12"-16" of wire that runs parallel to the canister vent hose that comes off the bottom side of the upper intake manifold. That hose connects one port of the solenoid valve; the other port connects to the carbon canister.
The purge valve solenoid should be available at your local auto parts store.
Purge valve solenoid:
The carbon canister is normally mounted on the passenger side frame rail near the smog pump pulley.
Carbon Canister:
Both codes can be the evidence of vacuum leaks, which can make it almost impossible to get the engine to idle correctly.
Killa
1,006
56
49
Jun 9, 2014
#76
  • Jun 9, 2014
  • #76
Carbon Canister:
Thank you, my last message.
CarMichael Angelo
8,909
234
Birmingham, al
Jun 9, 2014
#77
  • Jun 9, 2014
  • #77
Well, I wonder who peed in his Wheaties?
stykthyn
5,232
2,652
223
gainesville
Jun 9, 2014
#78
  • Jun 9, 2014
  • #78
My money says foxmustanglver
Reactions: FoxMustangLvr
FoxMustangLvr
I love my Pimp
Oct 14, 2012
4,968
3,514
204
Spokane, Wa
Jun 9, 2014
#79
  • Jun 9, 2014
  • #79
Reactions: v8stang289, tamadrummer88 and stykthyn
tamadrummer88
599
79
39
Aloha State
Jun 9, 2014
#80
  • Jun 9, 2014
  • #80
Killa said:
I dont give a **** of what you say bro, get a life, instead of worried about other, you aint helping anything at all. **** you and your mom and your family and your whole generation , I dont give a F***. Ban me IDC, I feel peoples insulting / attacking me and Sh!T, F*** all you mother F***er that insulting me. I aint coming back here no more. Thank for all that been helping me, and other F*** all yall mother F***er. Some day you gonna die.
You know what dude, you just screwed yourself. We have been trying to help you, and trying to understand what the bloody hell you're saying, because no one can understand what you're saying. Everyone here has been giving you solid advice, this and that, trying to get to know you, but all you do is deflect everyone's questions and go off on a tangent, with worse english than before. 28 years in this country, and your english is that bad? i call Bull. Its fine here and there to talk, but once you tell someone to go f**k themselves, go die and whatnot, you just earned a place on nearly everyones s**t list.
Good luck with everything else.
  • 3
  • 4
  • 5
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
W
  • Locked
Fox Wifes 1993 LX 5.0 dies after replacing ignition parts
  • Warhorse85
  • Aug 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2025
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
