Car feels sluggish at part throttle
It could just be me, but my car seems a bit sluggish in normal driving conditions. It just kind of feels like it doesn't really want to go until I get into the throttle a good bit. It doesn't miss or anything like that and once I hit full throttle she seems to run fine. Just wondering if anyone else has experienced something similar to this. Thanks.
- Justin
in additon to advice above:run some seafoam through the brake booster line.Seafoam can be purchased at parts store for 5-6 bucks.Put half the bottle in a cup and let the vac line suck it up.
Might want someone to help you keep the car running
Ditto the heat idea. When I get the motor nice and hot (200*F) and ambient temps are 110* and I've been driving a bit (everything is heat saturated), mine's a dog unless I wind it out a bit too.
I'm going to play with my IAT because I think the CAI (chrome) is heating things up a bit (per resistance readings I took when I got home after a drive).
Good luck.
I know the MAF, ECT, PIP and IAT are good. They have all either been recently replaced or cleaned. Cleaning the TPS would be a good idea though, since I have never done this. I will do that tomorrow. Seafoam isn't a bad idea either but I'm not convinced that would fix the problem. Heat always affects performance but I don't think that is the culprit either. Especially since I have a Fluidyne, my fan is on all the time, and a cooler t-stat as well. The intake air could be hot but I don't think it would affect it this much. I have a cold air setup which would help me out a little here as well.
If this helps at all, I don't know if it is related, I have a bit of bogging feeling right when I push or let off the gas. It doesn't feel like the engine is missing or stumbling though. It happens when I let off the gas quick or when I get on it slow. It just kind of a little jerk or two. I'll try the TPS tomorrow. Thanks for the input. Don't hesitate to throw out other ideas. Thanks.
- Justin
Justin, I was playing with my IAT today. I was SHOCKED to see what it was reading in only 90* ambient temps. I have a MAC CAI which gets plenty hot. I'm playing with some ideas with that. It takes but 20 seconds to ohm out the thermistor.
Good luck.
Good luck.
I just finished pulling off the IAC and TPS and cleaning both. The IAC is pretty new and with the TPS there isn't all that much to clean. I didn't want to fire it up and wake the neighbors, so I'll have to wait until morning to see if it makes any difference.
I have the MAC CAI too, so I'm sure were in a similar situation. I remember reading that someone on here replaced the IAT sensor with a resistor. What do you think of that idea?
