car is having some issues.
i have a 88 coupe with a mass air conversion done, the car ran fine before but has started having problems in the past couple weeks and i cant narrow it down to what it is. whats happening is when the car warms up after a drive, when you start it back up the car will not go past 3000 to 3500 rpms, when you downshift to slow down it will backfire, the car when slowly taking off jerks and bucks pretty hard, and when trying to go say 35 mph the car jerks and bucks, sometimes when the car cools down and you start it up it'll run fine but will still jerk and buck, my timing is set at 14 degrees, my tps is set at .98 ive done the normal tune up, plugs wires, coil, cap, rotor. any help would be greatly appreciated. :flag:
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
i did get codes and it was just the emissions and egr valve not opening properly. my car stopped working all of a sudden one day needless to say i had an extra distributor assembly in the shop and i swapped it out and the car cranked back up, so the distributer and tfi module is old.
