Car Ran Great, Stumbled, Backfired And Died
93silverlx50
66
40
I've got a 93 LX with a 306, Vortech S trim,Cobra Upper and Lower inakes, 30lb injectors, MSD Dizzy, Ford Racing red wires and a factory coil, NGK plugs gapped at .042.
The car was running great but while driving last week I was in third and all of a sudden the car lost all power, backfired and stumbled into a lot. When I gave it gas it would stumble more. As I slowed to stop, it died. The car would not start. I played with the plug wires and when I grabbed one, it was loose, it seemed like it had been shaken or blown off somehow. I rechecked them and made sure they are all seated.
I went though the crank no start check list. Coil was bench tested, its good. I've got spark at the plugs. Fuel pump primes and plugs are soaked after it crank it for a bit. Injectors are firing. I cleaned the MAF and replaced the ECT. Now it'll start on occasion but rev over 2K then drop and stumble around 500 rpms. It almost sounds like it's running on 4 cylinders. It backfired like crazy, very loudly when it first starts. It'll die soon after it starts.
It's almost as if the timing is way off or the plug wires are out of firing order although the dizzy hasn't been touched.
I looked at the harmonic balancer and it's got pretty good wobble when it was running, motor seems to shake like crazy too.
Could these problems be the balancer?
I pulled KOEO codes and got 31 and 85. I looked them up but not sure it they will have anything to do with my issues.
I couldn't get it to start for KOER codes...
EDIT I got it to start, KOER codes were 12 and 21. (It wasn't at operating temp) it started and ran up to 2K RPMs were it stayed until I turned it off.
Any suggestions?
  • Sponsors(?)
jrichker
StangNet's favorite TOOL
SN Certified Technician
Mar 10, 2000
27,437
2,869
234
74
Dublin GA
lowendmac.com
A wobbly balancer is a must replace item.
See https://www.stangnet.com/mustang-fo...onic-balancer-removal-and-replacement.898122/ for a complete how to do it tech note on harmonic balancer replacement
After you replace the harmonic balancer, replace the coil next since it isn't overly expensive and is easy to change. If that doesn't fix it, look closely at the MSD distributor and TFI. MSD has a bad reputation for product quality and reliability. If You still have the stock distributor & TFI lying around, put them back on.
93silverlx50
66
40
Thanks for the suggestions. Your write ups have been great, thanks for taking the time to write those up and still take the time to chime in with advice. I'll give it a shot the next 2 or 3 weeks.
93silverlx50
66
40
I threw an old dizzy back in with the motorcraft TFI mofule. I was told it works.
After putting it back in I tried starting the car and it continues to crank but won't start. It let off one huge very loud backfire but still wouldn't start. Still think coil may be the culprit?
(Tried with spout, without spout, 1/4 throttle and full throttle)
When I test the coil with a meter it tests within range. When I check it for spark, its a pulsating orange spark, not a thick blue solid spark when cranking.
General karthief
Mod Dude
Aug 25, 2016
17,302
5,591
193
polk county florida
Find the 'cranks but no start checklist' in the 5.0 tech/how to threads.
If you do the steps in order it will find your problem, it will most likely be something you missed or did wrong/incomplete, the simple stuff will trip you up.
jrichker
Mar 10, 2000
27,437
2,869
234
74
Dublin GA
lowendmac.com
As karthief suggested, here it is...
Cranks OK, but No Start Checklist for Fuel Injected 5.0 Mustangs model years 1986-1995
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 16 Mar-2017 to add information on the ignition switch fuse link.
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD, Crane, or other ignition box if present - Bypass it and return to stock configuration if possible. Do this as a temporary measure to eliminate it as a possible problem source.
B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A – Using a noid light will tell if the PIP is working by flashing when the engine is cranking.
C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
D.) Coil
E.) No EEC or computer power - EEC or computer relay failure
86-93 models only: EEC relay next to computer - look for 12 volts at the fuel injector red wires.
Both 86-93 and 94-95 models: No 12 volts with the ignition switch in the run position on the fuel injector red wires. The relay has failed or there is no power coming from the ignition switch. Make sure that there is 12 volts on the red/green wire on the coil before replacing the relay.
F.) No EEC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. Look for a 20 gauge blue fuse link connected to 2 black/orange 14 gauge wires.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire on the ignition switch with it in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
94-95 models only: Check inside fuse panel for fuse #18 blown – 20 amp [fuse
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer. Don’t replace the computer just because you don’t understand how it works. Computers seldom fail, it usually is a sensor or wiring problem that causes the problems.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red/blue wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI.
See the Ignition switch wiring diagram for more information on the ignition wiring fuse link because it is the next thing to be tested. You will need a Multimeter or DVM and know how to use the Ohms function to check continuity between the red/green wire on the ignition coil and the red/green wire on the ignition switch. Make sure that the ignition switch is in the off position when you do the check. You should see less than 1 Ω (Ohm) between the red/green wire on the coil and the red/green wire on the ignition switch. More than 1 Ω means that the fuse link may have blown open and needs to be replaced. If you get 1 Ω or less means the fuse link is OK and the ignition switch is bad.
Wiring Diagrams:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
AutoZone wiring diagrams: You can navigate to the diagrams yourself via Repair Info | AutoZone.com and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 2-4 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
B.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
C.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
See the graphic for the 10 pin connector circuit layout.
The injector power pin is the VPWR pin in the black 10 pin connector.
D.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the EEC relay and the red wire for the 10 pin connectors.
E.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently. If you removed the distributor, there is a good probability that you installed it 180 degrees out of time.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it, if you get this far. If it starts, replace the ECT.
Thread starter Similar threads Forum Replies Date
Seclusioned Ran My Car On The Track Today... Not Happy! 1996 - 2004 SN95 Mustang -General/Talk- 25
4Jenna Ran the Car 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 12
302fordracer ran my car tonight for the first time 1996 - 2004 SN95 Mustang -General/Talk- 2
9 carfax? anyone have a car fax? i need my cobra ran. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
9 carfax? anyone have a car fax? i need my cobra ran. 1996 - 2004 SN95 Mustang -General/Talk- 2
L ran my car 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 18
25thmustang Ran my dads car at the track 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 26
Winters98GT Finally ran my car 1996 - 2004 SN95 Mustang -General/Talk- 12
HuebyStang94 ran car while overheated, loss of power now Fox 5.0 Mustang Tech 6
B ran out of gas and now car won't start Fox 5.0 Mustang Tech 12
NotQuik ran my car w/ 5 speed finally 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
W Went to a small car show and look what I ran into.(56k go detail) 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 30
blackstalion666 Ran my car for the first time!!!!!!!! Regional Forums and Event Information 12
lxwants12's just ran car 1st time with zex Fox 5.0 Mustang Tech 12
a_k So I ran my car with straight headers.... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
Daniel50 Results!!! Ran car with only underdrive pulley's as change! Fox 5.0 Mustang Tech 0
5.0_GT_kid Ran car at track 1994 - 1995 Specific Tech 7
KTD SC Finally ran my car... 1994 - 1995 Specific Tech 20
9 Finally ran my car, tell me if this is good/bad Fox 5.0 Mustang Tech 12
K ran out of gas car won't start?? SN95 4.6L Mustang Tech 10
A Ran the Car today 1994 - 1995 Specific Tech 19
M My cars tune is garbage, ran on the wideband SN95 4.6L Mustang Tech 1
ECU5.0 car ran fine...now it back fires Fox 5.0 Mustang Tech 15
3 Car ran lean on dyno SN95 4.6L Mustang Tech 9
H sorry guys i was wrong never ran my car! SVT Tech Forum 16
B Leather Seats for My Car The Welcome Wagon 0
9 Fuel Help - Car Won't Start After Braided Fuel Line Conversion Fox 5.0 Mustang Tech 3
W Engine Oil Change Interval for a car that is not used much ? Fox 5.0 Mustang Tech 9
L The quest for a 9 second street car The Welcome Wagon 12
B [Project Car] 1986 5.0 V8 Foxbody Mustang Starting Issue Fox 5.0 Mustang Tech 8
M giving up here, car instantly dies Fox 5.0 Mustang Tech 2
90sickfox Virtual Car Show here ??? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 39
B AC causes car to over heat Fox 5.0 Mustang Tech 28
M Engine car cuts out without revs Fox 5.0 Mustang Tech 3
R Engine Car has no power under acceleration, but has no codes 1994 - 1995 Specific Tech 3
T HELP MY CAR IS RUNNING TERRIBLY! 1996 - 2004 SN95 Mustang -General/Talk- 1
E Any way to tell if my car is modified? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 64
A Electrical Help. I’ve about had it with this car.... Fox 5.0 Mustang Tech 12
silverlx50 Engine Car spewing fuel Fox 5.0 Mustang Tech 27
7 Progress Thread Oregon Pace Car Story to Coolness 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 64
7 New Guy from Oregon 79 Pace Car 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 16
A Car starts but dies Fox 5.0 Mustang Tech 2
93silverlx50 Engine Car in limp mode, fuel spitting out of tailpipes, missing rough idle Fox 5.0 Mustang Tech 9
T Decent deal on these cars? Or keep looking? 2010 - 2014 Specific Tech 4
R New car! 2015+ (S550) Mustang -General/Talk 2
CrazyRedFox Fuel Noise from the rear after shutting off car Fox 5.0 Mustang Tech 7
slayr281 Hey, I know that car! 2015+ (S550) Mustang -General/Talk 0
M For Sale FS: 2000 Mustang GT Track Car / 62k Miles / 5k on Motor / Full Roll Cage / California / $5,000 OBO SN95 Mustangs For Sale (1994-04) 0
Olivethefet Drivetrain One Man T5 Tailshaft Housing Install In The Car Fox 5.0 Mustang Tech 6
R Fox 1987 Charcoal Canister Test - Test off car 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
