Car "Slams" into Gear
  • Thread starter Thread starter 1989MustangLX
  • Start date Start date Jun 24, 2005
1989MustangLX
118
Canada
Jun 24, 2005
  • Jun 24, 2005
I've been having this problem for awhile. The car idles nice, but as soon as you put it into R or D, it slams roughly into gear and sometimes stalls. On wet or smooth pavement, the tires squeek. I can't imagine this is good for any of my drivetrain. Would turning the idle down help out? I think its at 7-800 rpm. The tach is still the 4 cyl model, so I divide it in half. Thanks for any ideas.
The Shape
2,224
East ARKANSAS Delta
Jun 24, 2005
  • Jun 24, 2005
800 RPM should be ok, but from what you describe it sounds like it is idled way to high. Are you sure you can trust the tach you have?
1989MustangLX
118
Canada
Jun 24, 2005
  • Jun 24, 2005
I doubt I can trust many things with this car. It sounds higher than 800 rpm, more like 1000-1200. I forgot to mention, this is an FMX.
The Shape
2,224
East ARKANSAS Delta
Jun 24, 2005
  • Jun 24, 2005
Reason I ask is because my 4-popper does the same thing, but it is because it idles at 1100 (I don't know why it idles that high or do I care cause it's just my beater) But it does the same exact thing you are describing.
nosmatt
1,356
Bass Lake, Ca
Jun 24, 2005
  • Jun 24, 2005
why dont ya flip the switch to 8 cyl?? (or, do they have that after the 79-86 cars, i know they did...)
anyway, sounds like the idle is too high, and/or it has a mal adjusted tv cable.
1989MustangLX
118
Canada
Jun 24, 2005
  • Jun 24, 2005
Tach doesnt have a switch. I think I found what it is. I got under the car with the tranny in neutral, and the driveshaft moves back and forth a bit before the wheels start to move. This leads me to believe that the rear end may need to have something fixed inside.
6SpeedLX
100
Mass
Jun 24, 2005
  • Jun 24, 2005
maybe your U joints are going?
1989MustangLX
118
Canada
Jun 25, 2005
  • Jun 25, 2005
I can see the pinion gear moving too, before the wheels are moving. Well, I can't see the gear itself, but the shaft the driveshaft bolts to.
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 30, 2026
badmech
Drivetrain Why does my AOD make a 'whirrring sound' when in gear?
  • evintho
  • Feb 7, 2025
Fox 5.0 Mustang Tech Feb 15, 2025
evintho
Drivetrain Fox Power Loss While In Gear
  • J_5.0_VERT
  • Dec 17, 2024
2K
Fox 5.0 Mustang Tech Dec 31, 2024
J_5.0_VERT
