Car wigged out on me here be the codes......
67o Neutral drive switch
84o egr vacuum regulator
29c insufficient input from vss
33c egr not opening properly
56c MAF above maximum voltage or transmission sensor failure
66c MAF fault below minimum voltage
87c Fuel pump primary circuit fault
96c Fuel pump relay open
Car would load up on me and stall when clutch was depressed.
93 GT 5spd with a 351W and a PMAS velocity MAF.
Could the VSS cause these problems or should I look to the MAF???
The MAF is probably the source of your problems.
The two codes for the fuel pump are significant if you have a no start condition.
