Car wont start...need assistance
97GTSTANG
852
Virginia
I went to start my car tonight after work and it wont crank over. it was quiet, not even trying to crank. however i can hear the fuel pump coming on. the headlights came on, the interior light came on, but the radio wouldnt come on, and the door locks wont work. Can it be the battery, or alternator? any suggestions?
Sounds like the battery is ded, does it make a clicking noise when you try and start it or is it completely quiet? The alternator has nothing to due with the car starting, it keeps charging the battery while the engine is running. The only 3 real things that start the car is fuel, battery, and starter. And you said that the fuel pump comes on, so that leaves battery and starter.
Its completely quiet, when i first tried it, it did make a sound like it wanted to start, then i tried it again and no sound, completely quiet. I will change battery tomororw and see if that works, if not, where cna i get starter from? get oem or aftermarket, any difference?
could be the battery, but it also could be the alternator. if the alternator wasn't working properly for a while the car could have been running off the battery alone for a while and slowly drained to the point its at.
you should be able to take the battery to any "advance auto" or "auto zone" and they will test it for you. if the battery tests good then you know its the alternator
yeah your problem at the moment is the battery is dead, you could just put a charger on it and let it sit for a bit and it should start again. You just need to figure out what caused the battery to die, it could be you left an interior light on or the headlights on or something like that, could be a charging issue with the alternator, or the car could have just sat in a garage for awhile and the battery slowly died. I would take it to autozone and have it checked, make sure its ok and go from there.
thanks for the advice guys, well i finally got it checked out, and the starter results is at 799MS. not sure what that means but the tech says its normal. The alternator is at 14.17 with no loads and 13.95 with all loads. he said thats normal too, however the battery says 12.35V 350CCA he said it should be at 630CCA to be normal. What do you all think, is the starter and alternator in normal shape, or should i get them replaced also?
just the battery then, old and weak is all.
I would suggest getting a good one, the cheap ones always give me problems so now I always spend a little extra for the better ones
Thanks, what do you suggest is a good battery? Best place to get one? What CCA should i look for? I live in VA it gets cold here. I think the one i have now is above 600, does it make a difference?> i have seen some at 550CCA
Get the Optima yellow top...one of the best batterys you can get...
trying to spend under $80. any suggestions. I heard about the Optima, but also i heard i have to modify the plate since its a smaller battery. anything i can pick up from autozone or advanced auto that is better than another. hwo about the CCA, any difference?
Well, the battery died again. Now i am not sure what to do, i just got the battery about a month ago. They have checked the alternator about 3 months ago and it was showing 14.17 with no loads. I am not sure if i should just get a new alternator or what? Any suggestions whatelse to do?Does Adanced Auto or AutoZone check alternators also?
