Car won't start
  • Thread starter Thread starter stanley514
  • Start date Start date Jan 20, 2004
stanley514
303
South Carolina
Jan 20, 2004
  • Jan 20, 2004
I have fire and fuel. I have changed the ECC and fuel pump relays the Fuel pump and the ign mod on the dist. Still the pump just runs nonstop.
J
jerry beach
2,671
Ocala,FL
Jan 20, 2004
  • Jan 20, 2004
How do you know that you have fuel? Are the plugs wet with gas? Do you have a FP guage on it? The pump should not run constantly, it should turn off if the engine is not turning. If you just turn the key to on, and dont try to start the car, does it turn off after 2-5sec? Did you mess with the timing? I take this to mean the engine turns over, but doesnt start. Is that correct. We need more info, its hard enough to figure it out when you are not there. Did you work on anything right before this prob ocurred?
staticc
234
Jupiter, FL
Jan 20, 2004
  • Jan 20, 2004
so you turn your key half way, and your fuel pump kicks on. and wont shut off?
post more info please.
stanley514
303
South Carolina
Jan 20, 2004
  • Jan 20, 2004
Won't start?
Ok I'm driving down the road and boom my car shuts down??
I had aready replaced the TFI and Fuel pump 2 years ago. It ran fine till now??
I have 3/4 a tank of gas.
I replace the fuel pump relay and the ECC relay.
Then I replaced the TFI Module. I have a spark its kinda red not real blue.
I then installed a new 255LPH fuel pump.
I checked the fuel pressure I have over 38psi.
I can hear a lot of nosie under hood it sound as if the fuel is rushing from the inlet to the return line. The pump keeps running it won't stop. The engine spins over fine but no start up??
The car is stock the battery post and wires are clean. All grounds good.
Is the ECM bad?? If I pull codes will it show any if the computers dead??
J
jerry beach
2,671
Ocala,FL
Jan 20, 2004
  • Jan 20, 2004
You should have a fat, blue spark. Suspect the coil first.
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
