10secgoal said:
Don't know if you want to do it or not. But it sounds like you are gonna have to start really learning this stuff yourself just so you don't have to pay these idiots to drag down you I.Q. while in their presence. Disconnecting the vacuum advance won't have a whole lot to do with WOT. It will depending on the size of your carb. It's mostly for driving. It really won't make a car detonate at idle.
I concur with your assessment. The problem is that if I have never done something before, it is difficult for me to know that I am not screwing up. Once I have observed up close and personal, then I am confident in my ability to do it myself. Like with re-loading. I bought all the stuff and had no idea how to use it. I was afraid to just start doing it because you can damage your gun if you put too much powder in. I had an old timer come by and we re-loaded together a few times until I got the hand of it and now I can reload a thousand shells with my eyes closed.
As for these guys who worked on my car, they were doing some big jobs that I could not have done because I don't have the space or the the tools or the techincal know how:
1. install power brake booster and new MC along with electric vacuum pump
2. tune the engine on a dynojet to determine optimum A/F and timing advance
3. install electric water pump and electric fuel pump.
to do 2 and 3, you need a dynojet, a wideband A/F tester, and lift only I don't have any of those in my little garage. I have a very small working space and even if I could have lifted the car up on bottle jacks, I still would not have had enough space to manuever.
The problem with the carb was a bad O ring and the starting problem was with the battery. I got the car back yesterday and it goes like a rocket. I am not too thrilled with the power band, however, as real power does not come in until later but that is a function of the cam that is in there and the 2000 stall TC. I will have to live with the cam but the TC locks up at low rpm while the engine is still making power and I know this is not optimal. First thing up is a new TC from Edge with a stall at about 2800-3000. Then I send the carb to Jet Performance for a Stage 3 work up. then I install a 125 shot of nitrous and this engine is as done as it will ever get.
