Car Wont Turn Off Now!!??
Alright I Have Just Developed A New Dilema. I Installed A Car Alarm On My Car Last Night....just Basic Hook Up To Get It Working For The Time Being. Power Ground Door Trigger Siren. All The Other Accessories I Didnt Hook Up Or The Other Things Are Power Windows Which I Do Not Have. Now All The Sudden When I Turn The Ignition Key To Off It Doesnt Turn The Car Off. I Can Take The Key Out And Still Acts Like Its In. I Have To Pull The Coil Wire To Get The Car To Turn Off. I Didnt Tap Into Any Ignition Wires Or Starter Wires So I Dont Know Whats The Deal. What Can Cause This...maybe Coincidence Something Just Went Bad In The Colomn?? If So What Needs To Be Replaced? Please Help Me!!
How did you hook it up if you did not tap into an ignition wire?
I would disconnect the alarm (remove fuses, etc) and see if it fixes itself.
Let us know if it is a remote start alarm (even if you did not hook that part up).
Good luck.
sorry for the caps...just easier to read. the alarm is a remote start alarm..no remots hookups used or hooked up. the alarm called for two seperate constant +12v power sources. i had one made already for some previous items..then i made another one from the batt for the second source.
